Thread: Help with my numbers
    Hello - I have a 8200 above ground vinyl pool. We started the BBB method last year, mid-year. The cover came off today and the water looked marvelous - crystal clear - first year since ever that it has looked that good upon removing the cover )
    My TF-100 kit came last week and I was able to use it for the first time today. Here are my numbers:
    FC - 2.5 - going to push that up to 5 ppm
    CC - 0
    TC - 2.3
    pH - 7.2
    T/A - 120
    CH - 270
    CYA - 40
    Shouldn't I shock by taking levels up to about 10 ppm - then letting it go to 5? I have a fountain and have found that the pH gets plenty high by running that, so should I hold out on the washing soda or borax?
    In the past our CYA was over 100, or so the pool store would report to me. Over last summer, we let out some water and then did again at closing, so it is either better or was never as high as the store reported to me.
    One thing I may have that the kit doesn't seem to measure is copper. Can I purchase chemicals to test for copper? I had a high reading last year due to too much algaecide added at closing the year before - I did add a bit at closing last year but was more careful.
    Thanks in advance for looking over my numbers and suggestions. I feel like I am beginning to know what I am doing this year. The BBB method is wonderful and only wish I had known of it earlier.
    Splash Pool - above ground - 13X21X4 - location - Kansas - 8200 gal. - sand filter -
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Help with my numbers
    Quote Originally Posted by hsmom
    Congratulations! Felt good, huh.
    CC - 0
    TC - 2.3
    pH - 7.2
    T/A - 120
    CH - 270
    CYA - 40
    Okay, I think your TC of 2.3 is just a typo.
    You can do an overnight test to see if you need to shock. If you should need to shock, the shock level for 40 CYA is about 15, not 10. See the Chlorine/CYA chart in my sig.
    But, you do need to at least maintain your FC between 3 & 6.
    Your pH & TA are fine. No need to add anything for them.
    One thing I may have that the kit doesn't seem to measure is copper. Can I purchase chemicals to test for copper? I had a high reading last year due to too much algaecide added at closing the year before - I did add a bit at closing last year but was more careful. See if your pool store will test that for you.
    Keep up the good work
    You're done SLAMing when:
    There is no need to shock as long as the water is clear.
    You can get a copper test kit, the Taylor K-1738, but it costs around $50.
