Thread: First time adding salt myself
    Hurricane Gio's Avatar
    Apr 2010
    Coral Gables, FL
    197
    My salt is down to 2900 and I figured to bump it up. according to the Pool School I should have it 200-400ppm HIGHER than the optimum level of my SWG manufacturers recommended setting.
    My Aqua-Rite T-CELL-15 recommends 2700-3400ppm. So I was thnk maybe 3200-3300ppm.
    What do you think?
    8,000 Gal, 11 x 26.8ft Shotcrete Pool with "Cool Blue" Diamond Brite by ESSIG Pools with Artistic Pavers Deck
    Goldine AQL-PLUS w/Aqua Pod, Aqua-Rite T-CELL-15 SWG, Pentair WhisperFlo High Performance 1.5HP, 2 speed pump, Pentair IntelliBrite,
    Pentair 100sqft Cartridge Filter, 6 Pool returns, Skimmer and 2 Anti-Vortex Main Drains
    Pool's completed build 2/2010
    Re: First time adding salt myself
    Yes, that sounds about right. The idea of having it a little high is that over the course of the season it will drift down slowly. By starting a little high, you will still be in a range by the end of the season (unless there is an unusual amount of water replacement).
    Apr 2010
    Coral Gables, FL
    197
    So I turn the SWG off for how long when adding salt? 24hrs?
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    It can take up to 24 hrs for the added salt to register
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    I shoot for 3300 for the same system, when I get below 3000, I add a bag of salt (blue bag Morton or Gem). BTW, I turn of my main drain when I add so it does not give the unit a false high salt reading
    South Florida. 20,000 gallons; 16x35 rectangular gunite; Pentair Intelliflo VF Variable Speed Pump; Hayward cartridge; Aqua Rite SWG. Dolphin Oasis Z5 Robotic Pool Cleaner; Kopec 540sc Electric Heat pump pool heater; Pool built in Spring 2004.
