Is it worth cleaning sand filter after 5 years?
bats
Jan 7, 2010
51
Hi i have a five year old sand filter witch is working great and my water is sparkling clean.Should i open it up and clean of the dirt on the top or should i just leave it the way it is till i start having problems.
I never touched it in five years.
Thanks
Richard320 said:
Just don't be surprised when you develop problems afterwards. There are gaskets and seals in the backflush valve that haven't moved in a looooong time. They may crack or tear if you use it.
I'm not quite understanding what you meen.Are you saying that i shouln't do a big long backwash?
Not at all! If you're going to backwash, make it worthwhile.
What I'm saying is that gaskets and O-rings get hard and brittle with time, and take a set. Disturbing them may cause them to start leaking. I don't know what style backflush valve you have, but if it's one of those old up-n-down push-pull valves, you may all the sudden see water dribbling out around the shaft. You may see strange things happen with pressure, you may see fine sand spewing out your returns. Or maybe nothing will happen. Just for amusement, go use the search box at the bottom of the page and enter "spider gasket," then read some of the posts. Then you won't be blindsided.
