Thread: Not algae but....Mosquito Larvae?
    I have a problem and am hoping chlorine can cure it. Mosquito Larvae, and they evidently do not care that the Chlorine level is 6 ppm. I did add some this morning, brought it to 10ppm, and am running the filter at present. Is this common? We ARE having a horrendous problem with mosquitoes due to having 22 inches of rain in 24 hours and living in a swamp. I am hoping the chlorine will kill them, but if not what will?
    Hurricane Rita did not kill me, but she killed my pool!
    Intex 36'X18'x52" "elliptical pool"/ Hayward 220 filter/1HP pump 14,364 gal, or so
    Houston, Texas, USA
    148
    Re: Not algae but....Mosquito Larvae?
    Quote Originally Posted by edbson
    I'm pretty sure mosquito larve stick to the surface. Scoop them out with a skimmer net.
    Poor Man's Pool
    Doughboy 18 ft round above ground
    7600 gal with center drain
    Pentair sand filter, 1 HP pump
    50 ppm borates
    "I know just enough to be dangerous"
    Pool Calc Ver 1.41 (Excel)
    Ahead of you, I have been scooping the m out, and catching them in the skimmer.......hopefully they will die!
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Unless your CYA levels are too high, your chlorine will kill them.
    Backglass's Avatar
    Jun 2007
    Putnam County, NY
    139
    Also...mosquitoes will not lay eggs in moving water. Maybe break up your pump timing? Say...2hours ON, 2 OFF instead of 12 ON, 12 OFF, etc?
