Thread: Before installing ladder and handrail....
    Hello
    Would there be something I could coat the ladder and handrail at it's base with to make it easier to come out of it's holder in the fall?? I have a salt water pool
    Thanks and happy strokes
    Tom
    Dec 2009
    Central Massachusetts
    2,690
    Re: Before installing ladder and handrail....
    You can use some marine grease, that works pretty well. Really any kind of grease that water proof.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    OK bk Thank you
    Tom
    Mantua, NJ
    80
    Caulk works great. Was discussed here.
    any-tricks-for-ladder-install-for-easier-removel-t12306.html
    Joe
    21k IG vinyl, 300 lb. sand filter, 1hp pump, Polaris 280 cleaner, 3/4hp booster pump, 240sq ft Fafco solar, Liquidator
