Results 1 to 8 of 8
Thread: HI FC
    Central Connecticut
    159
    HI FC
    Just tested my water. Have been fighting to get rid off cc's. Shocked it last night. Readings today:
    FC: 12.5
    CC: 0
    ph: 7.2
    CYA: 30
    Temp: 83
    is the 12.5 too high .. finaly at 0 CC. should I turn off my in-line tablet chlorinator for a couple of days till it comes down .. or just leave it all the way it is. ??? Was fC: 3 and CC: .5 before shocking last night.
    Also added Borax tonight to bring up the PH.
    thx
    18x36 IG 26,000 gal, Vinyl Liner, 24" Sand filter Hayward S224T, Jandy AE3000 heatpump and 1.5 HP SuperPump. Circupool RJ45 SWG
    Feb 2010
    Houston, TX
    271
    Re: HI FC
    If you haven't, you may want to do an overnight FC loss test. If the CL holds overnight, then go ahead and let it come back down. Is your water clear?
    John
    24' round Vogue AGP 12,000 gal. Flotec AT251001-01 1HP pump, Hayward S310T2 sand filter, Aquarite SWG T-15
    TF-100 (found at TF Test Kits) with Speedstir and Samplesizer
    Central Connecticut
    159
    Re: HI FC
    Yes the water is clear.
    Seperate issue .... I keep a solar cover on the pool. Will that have any effect on chemicals?
    Re: HI FC
    No negative effects....one good day of full sun and half of that chorine will be gone
    25,000 gal IG Utopia pool/Raypack gas heater/BBB
    Central Connecticut
    159
    Re: HI FC
    just did another fc test. now fc:11.5 cc: .5 ph 7.6
    small drop in fc. just can't keep cc zero
    Re: HI FC
    Having CC alternating between 0 and 0.5 is fine. Some pools always have a CC level of 0.5, which really isn't a problem. As long as CC doesn't go up to 1.0, don't worry about it.
    Central Connecticut
    159
    Re: HI FC
    Thanks. I guess I can stop chasing the .5 !
    On another post up the chain here ... someone if the FC held overnight. It went from 12.5 to 11.5 ? is that 1 considered a loss overnight ... or is ut insignificant?
    Re: HI FC
    A loss of 1.0 or less overnight is considered fine.
