Thread: Possible to retrofit return eyeball?
    The single return on my pool is just a hole coming out of the concrete. There's no eyeball, and seemingly no obvious way to install one. Is there a kit available to retrofit an eye-ball style return on these kind of openings? or would I have to have a pool contractor come out and cut into the concrete for this kind of install?
    Clearwater, Florida
    12,000 gallon kidney shaped gunite pool
    Pentair Whisperflo 3/4HP Pump
    Pentair CCP420 420sq/ft Cartridge Filter
    Pentair Intellibrite 5G 120V Pool Light
    South Central NJ
    3,192
    Re: Possible to retrofit return eyeball?
    What size is the hole? They make push in fittings for 1.5" pipe. Don't use an eye that is less than 1".
    Scott
    Owner of - PoolGuyNJ LLC
    The hole is probably 1 1/4" or so and it's oblong. It's basically like they built up concrete into kind of a lid that comes out of the side. It's very low pressure, even in pass-through mode.
    Clearwater, Florida
