Thread: 1HP 2 Speed Full Rated pump that runs on 115V for an AGP??
    So based on Jason's suggestion in my other thread I am looking for a 1HP 2 Speed Full Rated pump to go with a Hayward S244T.
    Well I need one that is for an Above Ground Pool (several for In Grounders)
    AND most importantly for 115V (they all seem to be 230V).
    Do these exist or are my Google Skills failing me?
    Oh and to make it tougher I cannot afford to drop $800 + on the pump. Hoping this exists in a sub $500 form (probably dreaming)
    Thanks
    Greg
    27' x 52" Round Lomart Sandstone AGP
    ~ 18,000 Gallons
    Hayward S244T Sand Filter 300lb
    Hayward 1HP Matrix 2 Speed pump
    2" Plumbing - 50 Foot run buried 18" Deep - Widemouth skimmer and 1 return with eyeball
    Compupool CPSC24
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    161
    Re: 1HP 2 Speed Full Rated pump that runs on 115V for an AGP??
    Here is a link to the one I use.
    Not sure if it's full rated but it does the job and the price is right
    http://www.poolsupplies.com/cgi-bin/com ... Parts.html
    Flow rate graph is on page 5 in the pdf catalog.
    http://www.waterwayplastics.com/catalog ... olpump.pdf
    Intex 15' X 48" metal frame pool
    Waterway Supreme 1hp 2 Speed pump
    Hayward X-Stream 150 Sq. Ft. Cartridge Filter
    2-2'x20' Sungrabber Solar Panels hooked up in parallel on a Goldline GL-235 controller.
    Not getting "Pool Stored" = Priceless!!!
    Thank you TFP
    Yeah I was just looking at that but frankly I am an idiot when I look at those things and have no clue what this all means.
    The Hayward S244T recommended Flow Rate on 2" pipe (which is what I have laid down) is 80GPM if I am reading their manual right http://www.haywardnet.com/products/manu ... ual145.pdf
    I am also running 50 feet on the suction and return side with 4 90 degree elbows which is why I believe Jason recommended a Medium to Full Head Pump
    Greg
    ~ 18,000 Gallons
    Compupool CPSC24
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    161
    I don't know what all the flow rates mean either, but if you wait a bit someone with the knowledge of such things will be along shortly to comment on it.
    Thank you TFP
