Results 1 to 7 of 7
Thread: Skimmer Trimmer Plate
    In our Pentair Bermuda Skimmers we have trimmer plates.
    When should these be used? right now it is set so it is not blocking either of the holes on the bottom.
    Thanks again!!!
    South Central NJ
    3,192
    Re: Skimmer Trimmer Plate
    Which are they? Hayward's or Pentair's? Bemuda skimmers are Pentair. Lets see a pic of the inside.
    Scott
    Owner of - PoolGuyNJ LLC
    Hi Scott,
    My fault...they are Pentair Bermudas.
    Also, noticed while I was underwater that the weir gate make a bit of a creaking noise when they go up and down...any solve for this too?
    thanks!
    South Central NJ
    3,192
    Are both ports of the skimmer in use? Often, only one is used. If both are used, are they used to tie drains to them, equalizing ports, or to each other?
    Scott
    i believe they link to the main drains scott....
    South Central NJ
    3,192
    I would only use the flap to cover the drain port when vacuuming.
    Not much to do about the squeaking though.
    Scott
    thanks scott!
