The pucks are the reason that your CYA is so high to begin with. Turn the chlorinator off and DON'T add any more pucks to it !!deepwater01 said:drained 1/3 of the pool... been adding 12% liquid shock ....4 cases on Saturday....non chlorine shock yesterday (3 lbs)....today I added 4 lbs.
CYA - 60 ppm (the home test is very difficult to get an actual read on)...I took in a water sample to make sure the reading was correct and it correlated to 60ppm
Additionally I have a chlorinator and just refilled with 6 (3inch pucks) on Saturday - because of how much shock and combined chlorine I had in the pool I turned down my chlorinator to 4 (out of 9)....however, as of this AM - the pucks are almost completely dissolved...do I potentially have a problem with my chlorinator?
Use the pool calculator and figure out how much BLEACH (or liquid chlorine) to add. At a CYA level of 60 your shock level is 20.
Please don't use anything but bleach right now... Your pH measurements go high when the FC level goes over 10 so start with pH of 7.2-7.4 and shock the pool until the FC holds overnight and the CC goes to 0.0 or 0.5 and the water is "sparkly"...
It will happen, but it takes time {and no pucks}!
Terry in NC
