Thread: bottom track spacing?
    I bought a used 24 foot AG pool that didnt have instructions. is there a standard spacing on the bottom track pieces? iv seen some sights say 1/2" and others dont say at all? Thanks in advance, im sure i will have more question in the future...
    24' x 48" Delair AGP (11,894.40 gal)
    Pentair Tagelus TA60D 24" (325lb) sand filter in tandem
    with Hayward 75 sf. cartridge filter
    Hayward power flo matrix pump 1hp
    Pool rover Jr.
    Taylor K-2006
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Re: bottom track spacing?
    Can you clarify what you mean on spacing? Are you asking about the size of the track itself or the channel gap or ? Each brand may be incrimentally different but I suspect structurally about the same to allow a steel or aluminum wall to fit and slide along it. Our track is about 1" wide and has about 1/4-3/8" channel for the wall to fit into.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    thanks for the quick reply. by "spacing" im referring to the gap (if any) in between each track/rail piece where they meet at each plate that hold the up-rites. i am thinking there has to be some gap i just don't know how much. oh, and while im thinking about it, should i use screws in the tabs to keep the track/rails in place? if so, should i put them in before or after the wall is in the track?
    Pool rover Jr.
    Taylor K-2006
    fordman's Avatar
    Jul 2009
    Iowa
    119
    Can you give us some pictures. Some have stops built into the plates to give you a gap. If it don't have holes for screws don't do it.
    1988 Ceder Ridge
    24' Doughboy AGP
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    What brand is the pool? Many of the manufacturers have online manuals
