Thread: When should vinyl liner be installed?
    May 2009
    Raleigh,North Carolina
    21
    Hello to ALL,
    My pool builder wants to install the vinyl liner however there is still water seeping in the bottom deep end hoppper. He placed hydraulic cement on the hopper floor but the water is still leaking in around the two main drains.
    Should I have the pool builder wait until the bottom is completely dry?
    Is this acceptable to place a vinyl liner with some water in the hopper?
    I know that once the liner is in place that the outside water will hit the liner then run someplace else. I have installed a french drain around the walls of the pool but right now the outside water has no place to go but in the hooper. The only other thought is to let it completely dry out and I have no idea how long that will take since we have been so much rain in nc.
    Any help would be greatly appreciated.
    Thanks
    Eddie
    Freeform 18' X 36: 20,100 Gallons: 2" piping, 1HP Pentair Whisperflo, Pentair Triton II Tr-60 filter,Pentair IC-40 Chlorine generator, dual main drains,3 returns,
    South Central NJ
    3,192
    Re: When should vinyl liner be installed?
    If it's less than a couple inches, go for it. The water will be pressed out and dispersed. As long as the temps are 65 or above, it'll be good.
    Scott
    Owner of - PoolGuyNJ LLC
    May 2009
    21
    PoolguyNJ,
    Thank You very much for answering my question.
    Eddie
