Large FC usage, and what level of FC to shoot for?
flyboy320
238
Burlington, Ontario, Canada
Here are my numbers;
FC = 5
CC = 0
TC = 5
PH = 7.6
TA = 60
CH = 90
CYA = 40
Borates = 50
Temp = 88F
The last couple of days I have been burning up between 4-6 FC a day. I did a drop test last night and it only dropped 1, so I guess those numbers are normal for me. The last two days have been very hot and not a cloud in the sky, and my pool gets full sun for most of the day. We have been swimming for a few hours each day and have had tons of pollen, actually dandelion fluff in the pool as well (just above the water line in the skimmer there is a yellow scum line from all the pollen). Water is clear and no apparent problems that I can tell from the look of the water.
So I have a couple of questions.
1. Is the chlorine loss I'm getting reasonable (I know each pool is different :) )?
2. If I am adding chlorine in the morning, how much FC am I trying to shoot for when I test again the following morning? I see the CYA chart says for a CYA of 40, the ideal value is 5, and min is 3. So in the morning prior to adding the chlorine for the day, do I want the FC to be at 5, or 3?
FC = 5
CC = 0
TC = 5
PH = 7.6
TA = 60
CH = 90
CYA = 40
Borates = 50
Temp = 88F
There's something using your Chlorine, and it isn't the sun at night.
Could be pollen, could be the swimmer load, could be - gasp - algae. You might want to push it up to shock level for a couple days, just to be sure. Beyond that, you want to keep enough Chlorine in there so that it doesn't drop below 3 before you can add more. If you're losing 4/day, then bump it up to 7.
A little more CYA will slow the loss, if you're in full sun.
