Here's pics of what I got installed now.
I'm looking to move the box about 1' to the side, and possibly 1' down so I don't have to pigtail new wires, and just keep the existing wires in tact. I'd like to cut the copper/emt tubes, and connect electrical PVC pipe w/ 90's to the new location. I'd also like to bring this up to code with GFCI/GFI protection. I don't need the timer or pump switch in the existing box, so I'll yank those out completely. If I ever add any additional components/lights, it will be LED/Low Voltage.
Main Panel-
- Double Pole 20amp for pump, single pole 15amp for pool light. I don't see anything for the outlet on the subpanel...
SubPanel-
- Pool lighting coming in from Copper pipe direct to switch
- EMT carrying the main power from main breaker box, with an outlet on the exterior of the box.
Questions:
1) If I can bend/but the existing copper and emt tubes, what connectors do I use to join with electrical PVC pipe?
2) Do I replace the breakers at the main panel with GFCI's? Or leave those and add additional GFCI breakers into the box?
3) Is it cheaper to buy a new box that comes with breakers (if there is such a thing)? Or, if I need to add breakers to the subpanel, is there a better box to buy that can accommodate that easier?
4) Any specifics on grounding or making this as safe as possible?
Thank you for your help!
Main Panel-
SubPanel-
Questions:
