20x40 rectangle liner pool convert to cinder block/concrete pool
mcrandolph83
6
West Deptford, NJ
I've read a few threads on here and I'm trying to get a better answer to this. What I want to do is remove my liner (20x40 4' shallow to 8' deep) and construct a cinder block/concrete pool. I'll be doing most of this DIY, but will be done next year as I am currently out of country for work. Here are my plans:
Before I begin, I bought this house 2 years ago and the pool came with it. The pool was left unattended/no maintenance for about 8 years. The "long walls" both caved in. I spent about $20K to have "professionals" come in and "fix" the walls, reshape the bottom and slopes and install the liner. Yeah, I fired them after the 3rd attempt of them saying "we can't fix this because of ground water". I had to reshape (to the best of my abilities) and tackle the ground water, which later I found out they had no clue what they were doing. The pool is in service and has been for 2 seasons. However, the shape of the bottom is horrible and I feel the whole area is out of date.
What I want to achieve with this build is:
1. Raise the pool 24" but keep the same depth. Currently I have a deck (pictures to follow once I locate them) that is roughly 24" above my pool deck. I plan on raising my pool to become even with the deck. This will help me with my ground water issues.
2. I do not like having sloping walls and prefer straight down the side walls.
3. I plan on moving all my equipment to a different area and creating a "pump house"
4. I would like to have concrete/cinder blocks as my main structure (no liner or fiberglass if i can help it)
My question is, am I setting myself up for failure to want to redesign my whole pool area? I've already done some quick math for the pool itself, cinder blocks, rebar, motor, concrete, concrete floor and that comes out to about $6K with me doing all the labor (minus pouring and shaping of the concrete floor) thanks for any advice and help.
Matt
mcrandolph83
6
West Deptford, NJ
Interesting project.
How do you intend to waterproof the concrete/cinder blocks
How do you intend to waterproof the concrete/cinder blocks?
After building the walls, I intend on "stuccoing" them, I say stucco because I don't know the correct term. But basically I will be coating the inside with a stucco mix. I read online that I can use some products on top of that to water proof it,I just don't know the correct products at this moment to use.
ajw22
35,166
Northern NJ
Pentair Intellichlor IC-60
You should consider having pool plaster installed for waterproofing.
Stucco that is waterproofed does not mean it will last in a submerged pool application.
mknauss
47,910
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Like I said, there are other cinder block pools that have been highlighted here in the forum. All that I know of have liners. And they do not have sloped walls. You build the pool with block and concrete and then water proof it with the liner.
mknauss
47,910
Laughlin, NV
Fiberglass
A couple examples. Lots more where they came from.
sls
Active member
Jun 13, 2007
26
Poplar Bluff, MO
Here is my concrete block pool with a liner with no slope on the sides. I like it because you don't have to worry about hitting a diving pit. It has a gentle slope from shallow to the deep end which is also good with kids. You don't have worry about them going past the ledge and sliding quickly into deep water.
Reactions: mknauss
mcrandolph83
6
West Deptford, NJ
What is the floor made of? Is it just a concrete floor or is it vermiculite? Thank you for the example. I'll definitely look into it.
mcrandolph83
6
West Deptford, NJ
Thank you so much. This will help me out tremendously.
Reactions: mknauss
