Thread: Good vinyl cleaner?
    flyboy320's Avatar
    Jul 2009
    Burlington, Ontario, Canada
    216
    Good vinyl cleaner?
    I have a dark (although very subtle) ring a few inches above the water line on our vinyl liner. I bought some vinyl cleaner from local spa shop called "Ultrashine vinyl & leather cleaner" and if I use it with a sponge, the dark rings will come off, but it does take a bit of elbow grease.
    I was wonder, first off, what would the stain be, is it body oil/suntan lotion?
    Is there a preferred cleaner that people here at TFP like to use?
    10K gal IG, vinyl, 1 HP Jandy Stealth pump, Jandy CS cartridge filter, Delta UV system, Hasa Liquidator
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Good vinyl cleaner?
    I've always used a paste made from baking soda on a sponge, and a fair bit of elbow grease.
    It's body oils/ suntan lotion and dirt that cause this and a ~ strong base helps dissolve it
    Luv& Luk
    -Ted
    flyboy320's Avatar
    Jul 2009
    216
    OK, thanks, I'll give that a try today...
