Page 1 of 3 123 LastLast
Results 1 to 20 of 60
Thread: Repair ropes on Coverstar autocover
    We have a Coverstar autocover that is 6 years old, 1 year out of warrenty. The ropes broke right after we opened our pool this year. I spoke with the installer and he said that Coverstar went to a new rope system and it would cost $700 to replace the ropes. That's very expensive rope! It seems to me that from searching the web that Coverstar only sells to contractors through their distributors. I'd like to replace the ropes myself so I don't have to leave the cover open all year. Can anyone help?
    Jim
    Re: Repair ropes on Coverstar autocover
    Did a quick fix and it's working fine. I could have purchased new lines at the local pool store for $175 each, $350 plus tax. It is good rope, 8.1mm / 3/16th with a 4,500# tensile strength. To replace it with 4,500# rope bought online would cost about $136. Since my cover is 6 years old, and I'm thinking about replacing it, I opted for poly rope that I got for 6 cents a foot, total price, $13.48. It works great, but I don't know for how long. It only takes about an hour to replace though.
    Jim
    My rope broke as well, but as luck would have it it was the last 12 inches that attaches to the leader bar of the cover. I was able to unwind the rope a little more from the spindle as the installer left extra. However, my next task is to reattach. The Coverstar rope has a cloth wrap that is sewn over the rope that leaves a tab that exposes to my leader bar. How did you attach your replacement rope?
    I used a seem ripper and a sewing awl. You could but 3" nylon webbing at a fabbric store and sew the new webbing to the rope. You can get a sewing awl at a saddle shop or Habor Frieght Tools, they're online.
    Jim
    Can anyone give me step by step instructions on repairing a broken rope on the coverstar? I have a top mount system. Do have have to take the track off to get to what the rope connects to? Any help would be appreciated.
    I took pictures of the process, but it will take a day or two to put it together. I have the toprail. The rope has 3" webbing sewn to the end where it attaches to the front of the cover by 3 or 4 nuts bolted to a plate. Remove the plate and detach the rope. Then remove the pully at the far end. Then loosen but don't remove the track. Remove the old rope. Sew 3: webbing to 5/16th rope. I needed a 95' and 115' length. Webbing runs in a channel on the pool side. The new rope is easy to put into the outer channel just by lifing the track and laying underneath. Run the ends through the pullyes and reattach to the drum with the screws and your done. If you have new rope with the webbing attached, it's an hour at most. If you post your email I can send pictures.
    Jim
    I think from your other posts and some other things I've found online, I've figured out how it all works. Where did you get your rope, and is it still working alright for you? Any idea where I could pick up the 3" webbing? That is where my rope failed. It ripped out of the webbing - it also has a gash in the middle of it, so will have to replace the rope.
    Quote Originally Posted by gglmn
    I need to replace my coverstar ropes and would love to use your pictures as a guide. Can you please send them to akakin@yahoo.com.
    Thank You
    I'm sure this will save me a big chunk of money.
    Can you please forward the pictures to me?
    dillydill AT Juno.com
    The closest Coverstar repair people are 2 hours away and want to charge me $400 just for driving time. My rope has torn at the nylon part and think I might be able to attach new nylon and get the cover working again.
    Thanks for your help.
    20K Gal Blue Plaster IG with rock waterfall, Beach Entry, Hayward Goldline Pro Logic controller and SWG,
    Sta-Rite System 3 S7M400 cartridge filter, 1-1/2 HP pump, Energy Therm Heat Pump, Nexxus Savi LED lighting
    500 Gal Dynasty Miramax Fiberglass Cinema Spa
    I just had my Coverstar rope break. I guess I am dense but I don't understand how the whole thing works. I also have the top mounted for a rectangular pool. I am looking to replace it myself and have read this thread completely. I would greatly appreciate it if you could send me your photos so I could use them as a guide. jcarron@cox.net
    J...
    I think my coverstar ropes also broke- cover not workin and I see a free end. Pictures would be greatly appreciated so I could learn how to splice/reattach.
    Thank you so much
    raisenberg@gmail.com
    35,000 Gunnite Rectangular Underground turbo clean- but I use robot
    Pool Pilot SWG
    Sta-Rite System 3 53 sq ft DE filter now with Zeofiber Haywood separation tank
    Coverlight cover
    Heat Exchanger
    Could you please send me the pictures to replace the rope on my coverstar cover? rmpeil@gmail.com
    Thanks!
    28,000 gals, In Ground / Plaster, spa, cartridge filter (STA-RITE System:3, 300 sq.ft., 100 GPM max flow rate), 2 HP pump motor
    Our coverstar ropes broke as we opened the pool before it snowed this last week. Can someone please post or send pics on how to replace? We have three small kids and the backyard is now a major safety issue. Thank you and happy holidays!
    Gary Linde
    lindeg@hotmail.com
    another one's Avatar
    Jul 2010
    Seattle area, WA
    49
    if some one wants to mail me the pictures, I'll post them in this forum.
    fred.hillen "at sign" gmail.com
    29,000 gallon, 18' x 44' Indoor plaster pool - 8'x'8 spa in corner. Well water, TF-100,
    pool cover, Pentair MasterTemp 400k btu heater, Jandy RS-4, 4 x 105 sq ft cartridge filters,
    Wisperflow WFE-4 1.0 HP pump for pool, WFE-6 1.5 HP pump for spa jets, MagnaSweep.
    i would love to get the photos also. ewf1@bellsouth.net . my rope did not break this time, the webbing tore loose because the plastic plate(wear plate?) wore through underneath it. so i think i need that and reattach the rope. thanks for any help i can get.
    Pool: 17,000 gallons, Cartridge filter, In ground vinyl, Polaris pool cleaner, Ozone Joe, BB Method (not currently using Borax)
    did anyone post pics? If you have them, could you please email them to me at jekenb@yahoo.com? Thanks!
    30,000 Gal IG Plaster Pool with Spa
    American Products Titan DE 60 SF Filter
    I have a 3 foot section of rope on the pulley end which ripped out of the cover on a below level track system. Wondering if the "webbing" could be repaired/replaced in the same way and if someone could send pictures that were available earlier to: mfpacovsky@msn.com .
    Thank you very much.
    Would someone please send pictures on repairing the rope on the coverstar cover, I am not paying these idiots a dime.
    My e-mail is: jtsahlgren@gmail.com
    Coverstar, coverfallenstar. Mine is 6 years old. one of the ropes breaks every two years. $900 to replace. Yacht rope is available and plenty strong. I'd like pictures also vsurg2@gmail.com. A couple of questions. Does the cover need to be "rolled up" ( open) to get to webbing (my rope broke just at webbing, webbing is intact). How do you get the rope around the far pulley. With the webbing attached to the rope I assume you have to feed the rope through the "outer" track, up around the far pulley, and back down the "inner" track to the winch. I'd like to hear how this is done. THanks much.
  20. Back To Top    #20
    p.s. my cover is the "underguide" type.
