Thread: cloudy/algae?
    Jul 2009
    Newnan, Georgia
    24
    cloudy/algae?
    I raised the fc to 7 last night and it has held today at the same.the water is still cloudy.How long will it take for it to clear?I have cleaned the filter the past 2 days and it was vaccumed today.Also is it okay to keep the fc at 7all summer or when this clears up should we lower it back to 4 or 5?
    25.6 K Gallon , 33' Round AG
    ProClean Cartridge Filter 125sf
    2 hp, 2 spd, 115 volts, 11.0 / 2.9 volts Waterway Pump
    Well water
    Re: cloudy/algae?
    Your FC is determined by your CYA level. Posting a complete set of numbers would help.
    coloeb,
    20k gal. IG fiberglass/plaster rectangle 32'x16'
    Hayward Superpump 3/4 H.P. primary Hayward model 5060 Booster Pump
    Hayward Pro Series High Rate Sand Filter
    Pentair Model 320 automatic Chlorine/bromine in-line feeder
    Jul 2009
    Newnan, Georgia
    24
    Re: cloudy/algae?
    FC 7.0
    CC 0
    PH 7.2
    TA 70
    CYA between 30 and 40
    Well water
    Re: cloudy/algae?
    Your shock level is 13 FC for your cya level. After things clear you can drop FC to 4 or 5 with no problems. I would suspect that the cloudyness is just dead alge and should be filtered out soon enough. keep the filter clean and continue to brush untill it clears.
    coloeb,
