Thread: Tip for measuring CYA
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    833
    For any newbs out there or anyone who has trouble testing their CYA check out the CYA Standard Solution at TFTestkits. For $8 you get a 50ppm solution that allows you to run the test and see exactly what that dot should look like at the end point.
    It is a no brainer to add to your order when you are purchasing your first TF-100 or even just getting refills.
    note: I have no affiliation with TFTestkits.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    jmack1159's Avatar
    Apr 2010
    Arkansas
    45
    Re: Tip for measuring CYA
    Cool! Thanks
    24' Above Ground installed March, 2010
    22 Sand Filter With Zeolite
    1.5 HP Motor Pump
    Successfully using the BBB Method!
    pool-school
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    833
    I thought I would resurrect this post since I have been seeing many new members complaining about how difficult the CYA test is.
    From TFTestKits:
    This is an inexpensive way to test the validity of your CYA chemistry as well as to verify your testing methods.
