Thread: Recommended CYA level in Sacramento
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    825
    What would you guys recommend for a CYA level in Sacramento? The pool is shaded a little in the morning by my neighbors Italian cypress trees and a little in the afternoon by the west side of the house. It is in full sun for at least 7-8 hours.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Jan 2009
    Cupertino, CA
    1,966
    Re: Recommended CYA level in Sacramento
    I'd go for 40-50, the higher end of the normal range. The Central Valley gets plenty of sun but Sacramento is only middlin'-south in terms of latitude.
    --paulr
    (Hey, I like that first line in your sig!)
    BBB "Intermediate Swimmer"
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    825
    Quote Originally Posted by PaulR
    I like yours too. I have only been doing TFP for a few months, but my mind is uncluttered with any pool store nonsense since I was a member of TFP before I ever owned a pool.
    I prefer to call it TFP rather than BBB since I believe that the true essence is:
    • Test accurately[/*:m:3m67myrz]
    • Know what you are adding[/*:m:3m67myrz]
    • Know why you are adding it[/*:m:3m67myrz]
    BBB doesn't really fit...I use Bleach and Muriatic Acid. BM isn't really a good acronym though.
    Rarely if ever do I use Borax or Baking Soda since my TA is fine and my pH tends to drift up.
    Half the members have SWCG so they don't even use Bleach.
