Thread: Hayward S240 Help!
    Rembert, SC
    3
    Hayward S240 Help!
    Hey guys, new to the whole pool thing (came with the house we bought). To make a long story short, I was seeing a good bit of sand in the discharge hole in the yard so I figured something was broken inside so I took the top off of the filter and the top elbow pipe was broken off at the threads and buried in the sand. I can get a new one for about $30, but can't figure how to get it to go on. I tried with the old broken one and the bottom pipe (which is exactly the same as the top one) interferes with turning the top one. Someone must know a trick how to do this...please HELP!
    (1) Pool size - I think about 35,000 gals? Pool is 20' x 40'
    (2) Sand filter
    (3) AG
    (4) Vinyl
    (5) Pump: 1.5 hp Hayward super pump Filter: Hayward S240 (I think 65 cfm)
    South Central NJ
    3,192
    Re: Hayward S240 Help!
    Here's the parts breakdown:
    http://www.haywardnet.com/pdfs/replace_ ... ay2009.pdf
    It should be fairly evident.
    Scott
    Owner of - PoolGuyNJ LLC
    Rembert, SC
    3
    Should be, but if you look at the diagram, the pipes are so close that the elbow from the top won't allow you to turn it as it hits the bottom one. Does this make sense?
    (2) Sand filter
    (3) AG
    (4) Vinyl
    South Central NJ
    3,192
    Unthread the bulkhead. Set the pipe and thread the bulkhead to it, not the other way around.
    Scott
    Rembert, SC
    3
    Gotcha Thanks so much for your help!
    (2) Sand filter
    (3) AG
    (4) Vinyl
