Adding DE to a sand filter
I recommend adding 1/2 a cup of DE, wait 60 seconds for things to settle, check the psi, and repeat until you know how much DE it takes to raise the psi by 1. Then you can use that amount of DE every time. For a small sand filter that will be much less than 1 lb, for a large sand filter it could be more than 1 lb. You only need to do the extra work once, and they you know how much to use.
