Results 1 to 7 of 7
Thread: Whats the Ingrediant?
    Does anyone know the ingrediants of the Natural Chemistry brand aka "pool perfect/ phos free"?
    It's a weekly algaecide I prchased yet doesn't indicate the ingrediants.
    If so, is it a product I should use? (in addition to my chlorine of course)
    I know polyquat is usually specified.
    Thanks
    Doug
    Aqua Leader 30' a.g, w/ Aqua Smarte Inline System (just for vacations), cart. filter
    Phos free removes phosphates, which is useless and can cause a cloudy pool when used in anything but small doses. Pool Perfect is an enzymatic product that breaks down oils and other things which can, but hardly ever do, partially clog filters or cause a waterline ring. Neither one is needed in a properly maintained pool.
    Guest
    IT is a mixture of Lanthanum Sulfate, Lanthanum Chloride, and Natural Enzymes. It is NOT an algaecide but rather a phosphate remover/enzyme combination. IMHO, it is an unnecessary expense!
    Mar 2007
    Knippa, Texas
    289
    Re: Whats the Ingrediant?
    Quote Originally Posted by dougs30al
    Not to be contentious, but the enzyme portion can be very useful (for indoor pools especially). But if you want that, just get the regular "Pool Perfect" and not the kind with the Phosfree.
    It isn't necessary, for sure, and it's DEFINITELY not an algaecide.
    ~Jules~
    My pool: INDOOR 13x27 rectangular fiberglass, built ~2001, BBB, TA-60 sand filter, Hayward two speed pump (1 hp/0.33 hp), 3/4 hp booster pump for solar heater
    Taylor K-2006 test
    Well, I guess that answers THAT question.
    So it sounds like another snake oil that my friendly pool dealer strongly recommended.
    Are there any negative side affects to using? I hate throwing out 40 bucks of "algae preventative".
    Doug
    Guest
    The only negative is in the way phosphate removers work. They can cause a temporary cloudling of the pool if put directly in the water and not in the skimmer and they collect in the filter as they remove the phosphates so your pressure might go up faster if there are phosphates in the water. I actually use the stuff (my PB gave me a LOT of it before he went out of business and lost his license to make up for some fo the screw ups he made on my pool construction. but that is another story that I documented on Poolforum.
    Mar 2007
    Knippa, Texas
    289
    Have you already opened the bottle? If not, maybe your pool store would give you a refund or at least an exchange. . .
    The Pool Perfect is good stuff. If you can't get a refund or exchange, just go ahead and use it. It would be interesting if you kept an eye out to see if you started getting a waterline ring after you run out of the stuff. . .
    ~Jules~
    Taylor K-2006 test
