Results 1 to 12 of 12
Thread: Calcium Chloride
    St. Louis, Mo.
    16
    Calcium Chloride
    I need to raise my CH in the pool. Do I need to buy this at the pool store or, can I use the ice melt that is 97% Calcium Chloride, If so should I dissolve the pellets first in water before I put it in the pool?
    Grecian/W a Step style,14ft by 30ft
    14,000 gallon,Fiberglass,
    Sand Filter
    Deepend 5ft
    Method(BBB)
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Calcium Chloride
    Froom Pool School:
    CH - Calcium Hardness
    Calcium hardness can be raised with calcium chloride or calcium chloride dihydrate. They are available in some areas as Peladow, Dowflake, Tetra Flake, or Tetra 94, often sold as a deicer by hardware stores, and some big box stores, in colder climates. Pool stores will carry either calcium chloride or calcium chloride dihydrate under a variety of names, including Hardness Plus, Balance Pak 300, Calcium Hardness Increaser, etc. Calcium products should be spread across the surface of the deep end of the pool.
    Most of us do dissolve it in a bucket of pool water.
    You're done SLAMing when:
    St. Louis, Mo.
    16
    Thanks. I'm kinda new to the whole "household items" to keep your pool going good. This is going to save me alot of money this way. This site is awsome. If I think about the money I spent for the last 7years on chemicals. A new BBQ Grill is on its way now.
    Sand Filter
    Deepend 5ft
    Method(BBB)
    Keep in mind that when you dissolve calcium chloride in water it gets rather hot. This isn't usually a problem as long as you are aware of it. You don't want to be reaching your hand into the bucket or spilling it on yourself right after mixing the calcium chloride with water.
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    Why does one need calcium chloride in a fiberglass pool? Is it for equipment reasons?
    20x40 IG Vinyl, 1.5 HP Whisperflo, Sta-Rite System 3 (300) Sq. ft Cart
    Intellichlor IC40 SWCG, 125,000 BTU Pentair heatpump, Polaris 280
    7' IG FG Spa, 2 HP Whisperflo, Pentair Dynamic III Cart (100) Sq. ft
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by TripleB4me
    It helps prevent cobalt spotting and helps protect fiberglass from staining. Could be more reasons....?
    Quote Originally Posted by Butterfly
    No, those are the two significant issues.
    St. Louis, Mo.
    16
    MY CH is reading at 210 I would like be a little higher.
    Sand Filter
    Deepend 5ft
    Method(BBB)
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by brettman40
    Yep, the Recommended Level is 220-320 for fiberglass.
    Mar 2010
    Spring, TX
    1,082
    I know how that is. I was told the same thing and felt the bucket and it was hot. I also touched the end of the pole I was using and it was hot. Had to be careful when I was pouring it in.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by mynewpool
    Also, use a non-reactive stirrer, like wood or plastic.
    Jan 2009
    Cupertino, CA
    1,966
    The recommendation I've seen is no more than 2lb calcium chloride per gallon in the bucket, to avoid excessive heat.
    --paulr
    BBB "Intermediate Swimmer"
