Spa Jet Blower problem
rkgdmd
Nov 25, 2007
65
Rockland County, NY
Hi All,
We have a 20 X 40 IG with attatched spa. The spa has eight jets. When I run the blower 2 or 3 of the jets deliver very little air. I am assuming (probably incorrectly), that the water column in those lines is preventing the air from being pushed through. The blower is 2 hp. What is the remedy? Can I safely attach my air compressor to clear out the lines? Any help would be greatly appreciated. Thanks.
Rob
PoolGuyNJ said:
There are 100's, if not 1000's of different ones.
Scott
Huh...Ya live and you learn.
Either way I'm not sure the problem is jet related. One has a single hole that doesn't move, the other has two holes and spins around. You can adjust flow by turning either CW or CCW..but the problem is there even if the jets themselves are unscrewed from the spa wall.
Rob
