Thread: cleaners for DE filter grids
    Does anyone use a filter grid cleaner along with a hose to clean the grids at the start or end of a season. I usually just use a power washer but I seem to remember something about soaking the grids in a solution. Has anyone tried the spray or soaking?
    Scott
    1) 24000 gal
    2) DE filter
    3) IG
    4) plaster
    5) 1 hp
    no-mas's Avatar
    Jun 2008
    FL
    405
    Re: cleaners for DE filter grids
    I don't use anything beyond a hose with an adjustable nozzle. I could imagine wanting to use a cleaner if I saw/felt them to be "sticky or gummy" from oils/lotions/cremes, etc, but after 3 years, all I've needed to do is to hose them off well. Still seem like new when I'm through.
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    monkeywrench's Avatar
    May 2008
    Shrewsbury MA
    84
    During the season I'll wash out the grid a couple of times, usually after the pollen and other tree discharge is done falling, and that is just with the hose, however at the end of every season after is all shutdown I clean the grid with the hose again then put the grid back in the housing fill it with water and use the liquid grid cleaner, soak it in the housing over night and rinse the next day, flush and dry the housing and air dry the now white (like new) grid, reassemble the filter and its ready for a new season next year.
    I most certianly removed the oils and greases, and yellow pollen staining. It always has great flow come spring start up.
    jb
    14x28 IG Vinyl
    12.5k gal
    Hayward SP-Super Pump
    Hayward Pro-Grid 36sqft DE
    Hayward auto chlorine feeder (offline:using BBB)
    Hayward AG Gas heater
    Mar 2007
    Coastalish 'down easter'
    4,160
    Hi folks, I seem to be considered the 'guru' on this issue here, so will post my thoughts.
    What I know, I know from a liberal mixture of experience and reading this site and PF. I authored this a few years ago and still stand by what I said.
    Filter cleaners are fine, but you can accomplish the same thing with automatic dishwasher detergent or TSP. (use 1 cup to every 5 -10 gal. water and soak for 3 - 8 hours - depending on the concentration)
    Most filters I run across don't need to be acid washed, but would benefit from a degreasing soak.
    Most folks here, like y'all, realize that the fabric of the grids can become congested with body oils and suntan lotion, etc. so need to be 'dipped' every year or so.
    Luv& Luk
    -Ted
    Thanks for the ideas! I am going to wait until the pecan tassels all fall and the pollen has dropped. I will use the tsp, with those concentrations.
    Scott
    1) 24000 gal
    2) DE filter
    3) IG
    4) plaster
    5) 1 hp
