... OK not really, it's 74F, but that's what the equipment is reading! :?
Intellitouch i5 system with an all Pentair supporting cast including MasterTemp heater.
I noticed a few weeks ago that the water temp sensor would intermittently indicate the pool was boiling and thought nothing of it. Hey, I have a regular pool thermometer that I trust more than that reading anyway!
Now I come to heat up the spa and, of course the system thinks the water is over 102F and won't spark up the heater.
(As a side note I cannot get it to start manually but that's more than likely use error.)
My initial reaction is that the sensor is on the fritz and replacing it should do the trick.
Something like this for ~$50 looks like the exact match:
http://www.aqua-man.com/row_num.asp?ic=2416&froogle=1
Before I go ahead..... I thought I'd check in here and see if anyone wiser than me has any pointers?
Thanks in advance :-D
