Results 1 to 9 of 9
Thread: DIY Pool Tile
    DIY Pool Tile
    Is Pool Tile something that can be DIY?
    Pool Size - Trying to figure that out. SBMW 2000 (2048 Model) Inground Pool.
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    Re: DIY Pool Tile
    Yeah if your good at it.
    14x33 fiberglass freeform
    Variable speed Pentair intelliflo superpump
    420 Clean and Clear Plus cartridge filter.
    pool-school/pool_calculator , http://www.tftestkits.net/
    Re: DIY Pool Tile
    Yea that is the problem, I have done ktichen tile but not pool tile. Im guessing it is the same processes right?
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    Re: DIY Pool Tile
    Yes but you use slightly different materials that will hold up to chlorine.
    Lana537's Avatar
    May 2009
    The Triangle, NC
    242
    Interesting question
    This is an interesting thing to ponder.
    Somewhere, maybe on this forum, I read that tile is like paint--it will look only as good as the surface onto which it is applied. I read this too late to save my own water line.
    We just went through a pool renovation. Professionals installed our tile, which is small 1-inch by 1-inch tile. They did not take care to have a perfectly even surface beneath the tile. Most of the tile area is almost flat, but there are a few linear feet that are just embarassingly bad. We were too worn down to have it redone. Many things had to be redone, so the tile was not one of the battles chosen.
    I am saying all this here because it is possible that a DIY pool owner may actually take more care to do the job well than a pool builder's crew might do.
    Just because someone is a professional doesn't guarantee that they will always do a stunning job. It doesn't matter how many gorgeous pools I saw before going with my builder.
    Lana
    23,600 gallon, refurbished 1960's inground concrete, Jandy sand filter w Jandy 2 hp variable speed pump, Pool Pilot Digital SWCG+Chemtrol 2100+CO2 tank; PebbleTec White Pearl with 10% Cobalt Blue Dark Beadcrete by Olympic Pool Plastering, Georgia. Taylor K-2006 Test Kit; Aqua Check Salt test; LaMotte borates test, and Jack's Magic Sequest test kit; SparklyPoolitis level: extremely high.
    Henry Porter's Avatar
    Nov 2008
    Sweden
    604
    Re: DIY Pool Tile
    Words Lana
    Many work task on a pool is not rocket science and doesen't demands years of experience to do yourself if you have the time to spend. The avarage contractor doesen't have that time beacuse then you don't wanna stand there with the bill. Of course can't you beat a real pro if he makes a good job, but a sloppy job made out of a pro is something you absolutely can compete with if you take the time.
    So my advice to the thread maker is: Prepare yourself and the surface and you will be fine. Just make sure that you use the right materials. And if you have made it yourself you have more understanding if the outcome is not exactly the way you had it plan!
    Inground concrete pool 14600 gallons,Pentair Whisperflo 3/4HP WFE-3, Hayward swimclear 420sq ft
    Zodiac LM3-24 SWG, Dolphin Diagnostic poolrobot, Heatpump Gullberg&Jansson 13,8KW, TF testkit.
    Seen a shooting star tonight And I thought of you You were trying to break into another world A world I never knew
    I always kind of wondered If you ever made it through Seen a shooting star tonight And I thought of you
    Re: DIY Pool Tile
    Thanks everyone for the good advice I appreciate it.
    Nov 2009
    Indialantic, FL
    323
    Re: DIY Pool Tile
    Here's the thing about a DIY tile install: Since the water line is mid-point on the tile, your accuracy in tile layout is critical. Like many types of jobs, the prep work is the key. Every pro I've seen set a line on the shell using a water level - don't trust the shell itself to be true. Also unless your shell was very well done, the brown coat for the tile install will need to applied to make up for waviness in the wall - I don't think thinset has the strength needed to bridge the crests/troughs of a wavy wall.
    Geometric 16X36', 16K gal, shotcrete, exposed aggregate plaster, acrylic coated concrete deck/cantilever coping;
    Pentair equipment suite (EasyTouch w/wireless, 2 Intellibrites, Intelliflo VS-3050, C&C 200 Filter, IC-40 SWG);
    Heliocol solar panels, Rocky's Roller, Blue Diamond robot
    Re: DIY Pool Tile
    One quick question is their an alternative for pool tile?
