Thread: test kit ?
    May 2009
    south jersey
    49
    test kit ?
    Walmart sells a pool test kit for 19.99 it tests for 8 diffrent things is this any good or do I have to buy the tf-100 for 80.00.
    Vinyl pool 37,000 gallons 2hp hayward , sand filter, true L 18-41-16-28 - 9 foot deep end .. Solar panels with goldline automation ..3/4 hp polaris 380 ..BBB method
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Re: test kit ?
    This article in Pool School may help answer your question:
    http://www.troublefreepool.com/pool-...kit_comparison
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Re: test kit ?
    The Pool School article does not address the one Walmart sells which is the HTH kits which really only will test 5 things in your pool - Tests for total chlorine, bromine (not used), pH, total alkalinity, total hardness (calcium hardness isn't that big of a deal for vinyl pools unless you have a SWCG), and cyanuric acid/stabilizer
    You get what you pay for - the HTH will not test FC, CC and TC separately - it is very limited and will not show shock levels correctly either. It will tell you "up to 100 tests" but keep in mind that is combining all of the items in there, not 100 for each individual item. The CYA only gives you two tests. If you want a kit that does the same number as the TFP kit and all of the different items you need to check, you would have to buy several of the HTH plus some other items that it doesn't include. I went that route for a while until I had a forhead smacking moment when I added up the cost of all of those and the TFP kit was less.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    May 2009
    Mason, OH
    16
    Re: test kit ?
    I was once along the same line of thought as you. Why should I pay that much for a test kit? But trust me, get the TF kit, it’s the best investment I have made in my pool so far and it pays for itself over the pool season in chemicals I don’t have to buy to keep my pool looking good. The trouble I had with the strips and cheaper hth tests is that I always ended up saying well I think the chlorine is between 2 and 3 or maybe 4…..i’m really bad at reading those color charts. And also as stated above you can’t test for FC and CC, which is really important. Bottom line, to me the TF kit pays for itself within one season i would guess.
    20,000 Gallon In-ground Vinyl Liner
    Hayward Sand Filter
    CompuPool CPSC48 SWG
    May 2009
    south jersey
    49
    Re: test kit ?
    Well took the plunge and bought the taylor TF100 from this site cant wait to try it
