Hey guys.......
So this post stems from another post I had when my FC levels would not stay level and kept dropping about a month or so ago. When I originally noticed my FC levels off, I started checking things and noticed my SWG was showing 'no flow' so it was not making chlorine. I called my builder and he recommended I remove the flow/temp/salinity sensor and clean it. I did and when I restarted the system, it was fine and working again.
So I did an overnight chlorine drop test and determined I had an FC consumer in my pool. I started and completed my first SLAM successfully (took about a week) while keeping my SWG shut off. After the SLAM, I let my FC level drift down (with my SWG still off) to the appropriate level. Once there, I turned my SWG back on and all was good........for a day!
My FC levels again started drifting further down than they should. I went in to the iAquapure app to adjust the SWG % up, figuring maybe the high temps and pool use required more chlorine, and noticed the 'no flow' indication again. I stopped the system and restarted it, and the 'no flow' indication went away. I checked it for the rest of the day and all was good. Next day, I checked it first thing after startup and all was good. However, when I checked it again later that day, the 'no flow' condition was back. Another stop/restart and it went away.
Over the next week, I kept tabs on it. Basically, after a few hours of operation, the SWG would go into the 'no flow' condition. But once the system was manually stopped and restarted, it would go away and run fine the rest of the day. I phoned the builder and he sent his technician out. He determined the flow/temp/salinity sensor was bad and replaced it with the cable. That seems to have fixed the problem. He also informed me that my SWG was installed upside down; apparently the sensor needs to be orientated on the bottom of the SWG so the sensor is always flooded and in water. For whatever reason, the installers orientated my SWG with the sensor on top and I never questioned it since it was originally built that way. Not sure if that was the reason for the failure after 2+ years of operation (my pool is circa 2018) but thought it worth a mention here.
I also wanted to post this since my pool is newer and I don't have the 'daughterboard' reset fix, which I found while researching a fix for the problem. There may have been another resolution other than the replacement of the SWG sensor/cable, but since my pool was still under warranty, the replacement was free for me (nice!). Anyway, maybe this info will help someone with newer Jandy equipment, should they have the same problem in the future.
