Results 1 to 10 of 10
Thread: Yet another pump problem
    Oct 2007
    Asheville, NC
    43
    I just opened my pool this weekend and went to start the pump today and it is not working. It does make an electrical hum, so I figure it is seized or has some other issue. It was in my basement this winter and I did have a serious flood (11 inches on Christmas Day!), but did get the water out that day. My pump is the original from when the pool was installed, a 1 horsepower 1984 Doughboy Power Pack 1. It's on it's second or third motor. I have had various issues with it, from time to time, and have replaced the power cord at least 3 times.
    I suppose I could get this fixed or a new motor if it is totally gone, but I wonder about a new pump. I've read about the two speed pumps and saving on electricity would be good. Aside from electrical savings are modern pumps a big advantage? Do they work more efficiently or move the water better? If I run a two speed pump on low is there a possibility of circulation issues? I've read of people with oval above grounds with one return having issues on the far end with circulation. That is not a problem with my current pump.
    If anyone has any thoughts or suggestions on a possible new pump I would appreciate the advice. Thanks.
    1984 vintage 16x32 Doughboy vinyl AG w/deep end, Sand Filter
    Re: Yet another pump problem
    Several of the modern high efficiency pumps move more water per watt than any of the older pumps could, and running a two speed on low will save you even more electricity. Modern pumps usually have much larger strainer baskets that are easier to clean and don't need to be cleaned as frequently. The differences aren't huge, but they are there.
    While it is possible to have circulation issues with a two speed on low, it is relatively rare and can almost always be fixed by adjusting the return fittings properly (or worst case replacing the return fittings).
    Did you verify that you had electricity at the pump deck? With no hum at all it sounds like a breaker may be tripped or a faulty cower cord.
    coloeb,
    20k gal. IG fiberglass/plaster rectangle 32'x16'
    Hayward Superpump 3/4 H.P. primary Hayward model 5060 Booster Pump
    Hayward Pro Series High Rate Sand Filter
    Pentair Model 320 automatic Chlorine/bromine in-line feeder
    Oct 2007
    Asheville, NC
    43
    There is an hum, so there is electricity. I don't believe that is the problem.
    Tim23's Avatar
    Feb 2010
    Livingston, Louisiana
    61
    Quote Originally Posted by johannafin
    It could be that the rotor is stuck to the field/stator from corrosion/rust. Could be bearings stuck. Capacitor may be bad. Start switch could have trash on it. Many things could cause it. Are you able to turn the motor? Hope this helps some.
    Tim
    Delair 27', 52" round AGP. 19,300gal
    Waterway 22"/1.5hp pump, 2 speed/sand filter, BBB
    My BBB motto.."LESS IS MORE WITHOUT ALL THE CHORES, SO FOLLOW TFP AND IN THE END, THE POOL OWNER SCORES"!
    Oct 2007
    Asheville, NC
    43
    Ok, so I got the pump running, it was just stuck. However it sounds horrendous and louder than ever. I plan on getting a new 2 speed pump. I called one place today to ask a few questions about a Waterway pump. The woman I was talking to told me that it wasn't as important to get a pump with the same horsepower as one with the same amperage. My current pump is one horsepower and 10 amps. The Waterway 1 hp pump has 8.8 amps and the 1.5hp pump has 11.00 amps. Anyone have any opinion on this? I must admit to being pretty clueless this sort of electrical stuff.
    As an aside I had to go to the pool store the other day to return a defective bolt. (Strange I know, but the head just snapped off as it was being tightened.) So I decided to ask them about a new pump, even though I figured it would be pricey. This is the store where the pool was purchased 25 years ago, it is just down the road, and always has the gaskets, baskets, springs, replacement parts I need in stock. And I like to support local business. The owner, who has been there for at least 20 years, and bought it recently was confused about my request for a 2 speed pump. She said that she was aware of people using them for inground pools but this was the first time she heard about using one on an above ground pool! She couldn't find one in her book, called her supplier, and they never heard of using one on an above ground pool! She did give me a price on a new Doughboy Power Pak II, the same as my 25 year old pump. Making me wonder if there has been any improvement in pump technology in 25 years! I told her to Google above ground 2 speed pump and she would see that a bunch come up.
    Anyway, if anyone has any advice on my question above I would love to hear it. Thanks!
    If you want to match the performance of your old pump as closely as possible, then using Amps (as long as the voltage matches) is a better guide than using HP. HP ratings can be rather misleading. On the other hand, most people have a larger pump than they need, so going smaller often makes sense and saves electricity.
    Oct 2007
    Asheville, NC
    43
    I am finding this pump shopping to be very confusing. I think that the Pentair Dynamo, two speed, 3/4 hp pump looks good both in performance, quietness and price. I called the pool store and asked a few questions, I was told that all two speed pumps need to be hardwired. Is this true? The Waterway 2 speed pump I was looking at comes with a cord. Or is it just the pool store being overly cautious?
    Thanks again,
    Johanna
    There is no reason why a two speed pump would need to be hardwired when a single speed doesn't. It may simply be that the store doesn't have any two speeds in stock that include power cords.
    Oct 2007
    Asheville, NC
    43
    Well I ended up getting the Waterway Hi-Flo pump, 2 speed. It might not be the most efficient, but it seems to be running well. The noise difference with my ancient pump is remarkable. When on low speed you can't hear it unless you are standing on the deck right on top of the pump position. On high speed it is a very low hum. My old pump was almost as loud as a lawn mower! Thanks to everyone who answered my questions. It was greatly appreciated.
