Thread: Thinning Plaster Repair
    I have thinning plaster on the walls. I have several home projects this summer and just can't afford the $3000+ for a replaster. I have partially drained my pool and pressure washed the thin areas where algae are really digging in. I have a few spots where the gunite is showing through. I have a product from the pool shop called Pool Patch (portland cement with dry polymers). I am still not sure how to get started covering these bare spots up. Any ideas?????
    Sincerely,
    Quinn
    Dallas, TX
    24,000 Gallon Chlorine Pool
    In Ground Gunite
    Hayward Pro-Grid DE6020 D.E. Filter
    1.5 HP Hayward Northstar Pump
    Aquabot Robotic Pool Cleaner
    Taylor K-2006 Test Kit
    scubasteve's Avatar
    May 2009
    Houston, TX
    52
    Re: Thinning Plaster Repair
    Wow $3000 for new plaster? Maybe your market is different than mine and your pool might be different, but that sounds high. Definately shop around. Try going straight to the plaster companies rather than through a pool guy/store. That made a diffeerence of 700-1000 in our bids. Best number we got was $1700 for plain plaster, and just a hair over $3000 for quartz.
    Good luck.
    16,000 Gallon Inground Pool
    Hayward DE Filter
    Polaris 280 Pool Cleaner
    $1700 does sound more reasonable. In the meantime, the Pool Patch is working great. I chisseled out and filled some large spots and covered some bare spots. If I keep patching, I figure I will eventually have the entire pool covered and not need the professional replastering.. LOL
    Sincerely,
    Quinn
    Dallas, TX
    In Ground Gunite
