Results 1 to 7 of 7
Thread: Diagnose my plaster
    Diagnose my plaster
    Hey Gang,
    Over the winter, I bought a house with a gunite pool w/ spa. It was built in 2003. I opened it up last week and went through the normal process of cleaning up the water. Now that the water is clear, I've noticed the plaster is worn, but not knowing much about pools I don't know how bad. What do you guys think? Take a look at the pics I've attached. What is this caused by? Will I need to get the plaster replaced soon?
    20,000 Gallon Gunite IG Pool w/ AG attached Spa -- Built 2004
    Sta-rite S8D110 DE 106 GPM Filter
    Sta-rite Max-E Pro 3 HP Pump
    Hayward H300 Electric Pool Heater
    Polaris 380 Cleaner
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Diagnose my plaster
    Yeah, that doesn't look good from my limited experience.
    Our plaster experts are around but less frequent as right now is their busy season so helpfully you'll get a response soon...
    Quote Originally Posted by frustratedpoolmom
    Thanks. After a long day of research, I've concluded that I think my pool is showing obvious signs of spot etching. It seems that there is a lot of debate as to what causes this, but from what I've read many think its caused by an acidic water chemistry. I'm wondering if the plaster experts on here agree with that.
    If so, I guess at this point I need to decide what I want to do about it. I see that Jack's Magic makes a product for spot etching -- not sure if it works. I guess the other cheap option I could try is an acid wash, though Ilike the Jack Magic I doubt that's going to do much.
    Ultimately, if I want to rid the pool of this I'm thinking a re-plastering might be necessary. What do you guys think?
    Polaris 380 Cleaner
    Guest
    Do you have a SWG?
    Quote Originally Posted by salp
    Do you have a SWG?
    No, chlorine.
    Polaris 380 Cleaner
    Mar 2010
    Spring, TX
    1,082
    I am interested in this as well.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Mar 2010
    Spring, TX
    1,082
    Do any of the plaster pros have any feedback on this?
