Thread: Testing CYA w? TF-100
    Jul 2007
    Katy, TX
    188
    UGH! UGH! UGH!
    Okay, got the test last weds the 25th and tested. CYA was not registering (filled the tube all the way to the top and could still see the black dot - clearly). Added CYA that night. Tested agin this afternoon and once again it is not registering the CYA. Their was a slight difference in the water in that it was a little cloudy but I was still able to see the black dot. What should I do??? BTW -
    Clean and clear water
    FC 7
    CC 0
    TC 7
    pH 7.6
    T/A 90
    CH 210
    CYA 0
    temp 89
    **last week I added CYA, CH, MA and Baking soda (not in the same day) to tweak my numbers on the other stuff.
    Please help, I do not know what to do or maybe I am a moron and not doing the test right although I am following all the instructions. UGH!
    ~Andrea
    24,000 IG with spa and 4 ton waterfall. Equipment: Pentair 520 Clean & Clear, Pentair VS+SVRS Intelliflo, Pentair Whisperflo 2 HP, Polairis Cleaner, Intellibrites, Pentair Rainbow 320 in-line Chlorinator, Pentair Easy touch 8 wireless and spa side remote.
    How much CYA did you add and how did you add it?
    Jul 2007
    Katy, TX
    188
    I added 3.5 lbs in a pany hose and placed in the skimmer. I did it in the evening and ran my pool all night. By morning the hose was empty.
    ~Andrea
    Guest
    CYA can take up to a week to dissolve, even if non is left in the panythose. Give it a full week and retest. 3.5 lbs should raise 10000 gallon to between 30-40 ppm so if your pool is acually a bit bigger than you think it might not be enough to fully register.
