Results 1 to 7 of 7
Thread: 2" SAND FLOOR OR 2" SAND FLOOR W/ HAPPY BOTTOM PROS VS CONS
    Apr 2010
    St. Francis,MN
    16
    I have more questions for current pool owners. When the weather dries up and temp. warms also, I will be continuning on my project. I am considering a 2" +/- sand floor with the happy bottom over the top. Is that over kill, or will it provide a better floor and possibly extend the life of the beaded liner?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: 2" SAND FLOOR OR 2" SAND FLOOR W/ HAPPY BOTTOM PROS VS CONS
    I think you should get the happy bottom, not sure about extending the life of the liner but certainly a better floor (this coming from a sand-only base pool owner)...
    Apr 2010
    St. Francis,MN
    16
    Thanks for the info. I am going to try and get this thing up thid weekend, weather permitting.
    It is to late though get have the happy bottom in tome, however, I have talk to a few people who have used
    a carpet pad under their liner and have had very good success.
    11,969
    Ours has lots of "toe divots" from the installers failing to compact the sand very well. All the dust/dirt/pollen settle in them...I think some sort of barrier would have made a big difference - foam cove too... we don't have that and our sand cove has washed away in some areas...
    Apr 2010
    St. Francis,MN
    16
    That is good to know. I only want to set this pool up 1 time. I am some-what of a perfectionist and want to do the DIY job right the first time. I do have the foam cove that I am going to be using. I am also looking to aviod the foot prints in the pool.
    Jul 2008
    Solon, Iowa
    170
    Make sure you use mason's sand or other finely screened sand. The happy bottom or similar also helps protect the liner.
    15X30 AGP, Lomart beaded liner;
    1.5 HP Sta-Rite pump with 21 inch sand filter (Zeobrite media)
    Mineral Springs (Aquatrol) SWCG, Rigid PVC plumbing, 2 inch
    Four 4X12 Techno-Solis solar panels, rack mounted, Goldline Solar Controller
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Just be careful with the carpet pad, especially if you want to "do it right the first time" because carpet pad will rot under your liner after contact with moisture in the ground. Even with sand under it, it will conduct moisture from the ground underneath. I am also in Minnesota and I know that with the winter/spring thaw cycle, the ground will move a bit and moisture will wick up. At at some point you will no longer have that padding there. You can get overnight on the Happy Bottom or other appropriate materials from several merchants and it is manufactured to be used under a pool and be in contact with the moisture. The carpet padding does work ok under the Intex Easyset and Metal Frame pools because they are not permanently/long term installations so the pad is stored for the winter/spring thaw. JMHO -
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
