Results 1 to 10 of 10
Thread: Just opened Friday, pump broken, what to do?
    When we opened on Friday we couldn't start everything up because we needed to add water. We've been doing that over the weekend and was trying to finish the fill up today.
    Well, DH went out to check and there was water pouring our of our pump (it was not on). It was coming out of the part behind the basket. It's sort of a verticle circle where the basket part hooks to the motor part. There are several bolts? plugs? there and one is missing or broken or something.
    So now I have to call the pool store to have it fixed. I hope they can come out tomorrow. If not, I may have to disconnet it all and take it to a place down the road that fixes pool pumps.
    Anyway, is there anything I can do in the meantime to circulate the water (we have sumbersible pump) or do something to keep the water from getting green, algae growing etc? It's already looking worse than it did when they opened it on Friday.
    27' round AG, sand, Ohio, well water, 19,000 gallons approx., New owners to the pool.
    Re: Just opened Friday, pump broken, what to do?
    I can't be sure from your description, but it sounds like one of the drain plugs was removed and never replaced. If water is coming out of a threaded hole in the side of the pump you just need to put the drain plug back into the hole to seal it off. It is very common for the drain plug to be stored in the pump strainer basket for the winter, though it could have been put somewhere else.
    Thanks Jason - I'll check that. And maybe try to get some pics of what I'm talking about.
    If that's not it, can I somehow use the submersible pump to circulate the water?
    Wasn't anything in the basket.
    Nov 2009
    Fort Gibson, OK
    7
    From the pic, it looks like something is missing....a plug or a screw. If there is something in there, it might need tightened or need some teflon tape
    30K gal, 20x40 grecian, vinyl, inground. 1 1/2 hp hayward super pump II, Sta-rite sand filter.
    Ok, I finally found a parts schematic online. It does look like a drain plug/o-ring. I'll try and see if it's something that needs tightened or if it's missing. I have no idea where it could be. The pump doesn't get moved except to take it to the basement at the end of the season and brought back up at the beginning of the season.
    Dec 2009
    Central Massachusetts
    2,685
    Just an FYI. You really dont need to take the pump inside during the winter. Some people do, it doesnt hurt anything, but its really not necessery.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Even in Ohio? Really?
    Dec 2009
    2,685
    As long as the water is drained out, sure. Nobody I know does it and I live in NewEngland. Like I said, it has to be properly winterized, but it's fine.
    yea missing the plug 3/8 or 1/2 by the looks, pool store should have this in stock . If for some reason they dont go to the hardware and buy one. FYI a plug with a o-ring near the top of the treads and a kind of built in washer is called a boss o-ring fitting.
    coloeb,
    20k gal. IG fiberglass/plaster rectangle 32'x16'
    Hayward Superpump 3/4 H.P. primary Hayward model 5060 Booster Pump
    Hayward Pro Series High Rate Sand Filter
    Pentair Model 320 automatic Chlorine/bromine in-line feeder
