Lei Mend
18
Virginia
We have a brandnew Hayward Powerflo Matrix 2 speed pump installed April 2020 by a professional electrician. Everything was working fine until yesterday when I noticed that the pump won’t work on High Speed. But it works on Low Speed.
I’ve checked the pump basket and nothing is blocking it. No bubbles on the pump basket. Filter pressure is okay. All I hear is clicking sound as if the pump is trying to kick in on High Speed.
anyone have experienced this? appreciate any clue on what’s going on. Thank you
Dirk
8,627
Central California
Pentair Intellichlor IC-40
I would give Hayward a call. They'll likely know, but more importantly you can register your pump and/or start the warranty process if that's where you're going to end up. You don't want to try any DIY fixes while under warranty anyway, which could end up voiding it.
Reactions: kimkats
Lei Mend
18
Virginia
Thank you! Yes I’m sending an email to Hayward. I just thought there might be an easy fix so I don’t have to go through the lengthy warranty process
Dirk
8,627
Central California
There may be. Others here might know... just don't disassemble anything yet until you hear from Hayward is all I was sharing...
