2 speed pump for 24' ABG pool?
amoses
179
Keene, Texas
CircuPool Edge-40
I have a 24' abg pool that is old and I am replacing with an Aurora Resin Wall saltwater pool and Circupool Edge-40 swcg (I think, maybe the rj-45). I have a single speed 1.5 HP pump right now, sand filter, but think I should go to a 2 speed pump. However, I am not sure exactly the best way to use one. Do you just run them all the time on low speed? if so, then what is the high speed for? Do you put it on some kind of timer so that it runs part of the time on low and part of the time on high? if so, how do you wire it up to to to that? Or do they have some kind of built in timer function?
Sorry for my lack of knowledge. I tried searching threads, but it was confusing me worse, lol.
Mdragger88
2,999
Hernando, Ms
Intex Krystal Clear
Most just run on low all the time (or whenever you run it) for regular filtering/skimming. High is mostly just used for vacuuming & backwashing. You can just use a regular mechanical timer with it switched to low for however long u wish to run it daily & then over ride it (turn it off) if u need to switch to high to vac or backwash etc.
cowboycasey
8,648
Southern OK
CircuPool SJ-40
I would go to a VS pump, many more options for speed and saving money... and these probably cost less than the 2 speed your looking at :)
cj133
483
NJ
I run a Hayward 2 speed 1.5hp matrix pump 24/7. But keep in mind these pumps aren't 1.5hp they're 1hp at best.
I'm mentioning that because a real 1.5hp pump costs a small fortune and is far from necessary for your 24' AGP pool.
I do not know anything about the pumps cowboy posted so they may be great but the VS ones I've looked at were a lot more money than a simple 2 speed pump. A 2 speed pump also has less to go wrong.
For now I'm voting 2 speed pump 24/7 but reserve the right to change my vote. 😉
mknauss
44,033
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Mdragger88
2,999
Hernando, Ms
Intex Krystal Clear
That is a great write up & takes the mystery out of it mostly. At the beginning of this season my 1.5hp single speed Carvin above ground pump was to be replaced under warranty - i asked if they would be giving me a 2 speed due to the new regulations (the only info I could find at the time just eluded to the discontinuation of single speed above 1hp) & they had no clue what I was talking about. The only thing they carry is single speed 1.5 hp. & they had a room full of them.
reggiehammond
361
Fort Worth, Texas
CircuPool RJ-60 Plus
For a new pool with a SWCG, the VS pump is such an easy choice. Mine runs at 196 watts, 24/7, generating chlorine happily. Been the best choice I’ve made in regards to the pool, ever.
anotherpyr
101
Columbia, MD
Some areas have rebates/incentives for VSP pumps. This tends to make them cost more before the rebate, and less afterwards.
Now we just need a cash for single speed pumps so I can trade in my emergency 1 speed backup for a shiny new VSP. 😃
amoses
179
Keene, Texas
CircuPool Edge-40
Now I really dont know what to get. I was wondering why I was having a difficult time finding 2 speed pumps.
wireform
In The Industry
Aug 15, 2017
3,002
Spring Valley, NY
When the new mandate goes into effect there will be less and less rebates for vsp as there won't be new pumps which aren't vsp and the consumer will be forced to get it at his/hers next pump purchase.
MITBeta
371
North Attleboro, Massachusetts
I run my 2 speed pump on low 4-8 hours per day in my 24' AGP - just long enough to be sure there's good circulation. Since my solar cover is on most of the time, skimming isn't much needed. If it is, I might run a little longer.
I haven't run it more than 2 hours this season on high speed since I got a robot cleaner.
No need to pay VSP prices.
amoses
179
Keene, Texas
CircuPool Edge-40
My 2 speed pump does 896 watts in high. 171 watts in low.
if a pump does not say that it is "salt" friendly, will it still be okay? I was looking at this Hayward Matrix 2 speed pump. What do you think? I know both of you guys have a hayward matrix pump. Was it listed as a salt water pump?
wireform
In The Industry
Aug 15, 2017
3,002
Spring Valley, NY
I'm pretty sure it would be salt friendly since there's a good chance a consumer will be using it for salt water. The only part that I can think of to differentiate or make it more salty compatible would be the shaft seal.
reggiehammond
361
Fort Worth, Texas
All pools are salt pools to various degrees, don’t worry.
amoses
179
Keene, Texas
CircuPool Edge-40
I bought the same pump as you for my pool. It was on EBAY for $379 - $30 cheaper than the sellers online store price. I hope I made the right choice and that it lasts quite a while. It was much cheaper than the VS pumps I looked at. I appreciate everyone's input on this topic. Now I just have to order the pool and SWCG, lol.
