2” skimmer ideas for above ground pool
Chewanik
10
Essa, Ontario
Hello looking for some ideas on where to buy or how to make a 2” skimmer for an above ground pool! Can anyone recommend any in ground 2” skimmers that might fit? Has anyone successfully fit a dual port 1.5”? Has anyone reamed the typical 1.5” port bigger? I am getting an Aqualeader influence pool. Are the openings for skimmers all typical?
Thanks!
kellyfair
4,651
Tampa, FL
Intex Krystal Clear
So I’m assuming you mean you want a skimmer that has 2” fitting underneath?
You can get a Hayward like this one and don’t use the hose barb. I think one of these would work with 2” PVC.
@magiteck
Andrew_D
149
Manitoba, Canada
Hayward Salt & Swim 3C
@magiteck
This is the exact setup I have. The 1500 connector linked above will take a 1.5" PVC pipe inside, or a 2" PVC coupler on the outside.
Andrew
Reactions: kellyfair
magiteck
552
Neenah, Wisconsin
@magiteck
Yes it looks like that one will accept 1.5 pvc (inside) or 2in (outside), and then has the Hayward union connector that should screw onto the skimmer outlet.
Chewanik
10
Essa, Ontario
Is the 1.5" outer socket thread typical on Hayward above ground skimmers? I haven't got mine yet but I would imagine it will be a base model like this
Andrew_D
149
Manitoba, Canada
Yes, that is the 1091 skimmer. Same as above. This one is the wide mouth version. Threads on the bottom take the 1500 nut linked above.
Andrew
magiteck
552
Neenah, Wisconsin
Just to confirm what Andrew said, the outer threads on the skimmer are a proprietary Hayward union connection. You have to use their union/nut as Kelly linked to.
The other end of that nut (slip/socket) are standard pvc sizes.
Reactions: Andrew_D
Chewanik
10
Essa, Ontario
Thank you for the replies really appreciate it! I am seeing this part in stock in Canada SP1500UNPAK2. It looks like the difference is the male end is threaded? I would have to buy a 2” female threaded adapter in order to connect? The Hayward skimmer connection looks the same.
magiteck
552
Neenah, Wisconsin
The SP1500UNPAK2 has a 1.5in male threaded connection, it doesn't have the built-in 2-inch option like the one Kelly posted. So you'd need an adapter(s) to go from 1.5 female pipe thread to your 2" pipe.
Will Amazon US ship the other one to Canada? If not, it looks like this eBay seller will:
Chewanik
10
Essa, Ontario
Thanks! Got it ordered. Appreciate all the help!
Andrew_D
149
Manitoba, Canada
I ordered my 1500 package from amazon.ca
It was the 1.5" slip / 2" spigot PVC pipe connector. Not the threaded one.
There definitely are various combinations out there (threaded, barbed, PVC slip, PVC spigot, etc), so have to watch out, for sure!
Andrew
