2" PVC fitting with hole for pressure gauge. Does it exist?
impeller
39
south of Atlanta
As I plumb the new pad...just a thought.
Does a coupling or tee exist that you could screw in a pressure gauge for evaluation or troubleshooting? Would it be desirable to have some of these in various places on the pad?
You could make one by using a tee and a slip/thread bushing, but maybe it would cause turbulence and restrictrion to flow...
You'd probably normally run with a plastic plug in the port, and just screw in the gauge when testing.
Bama Rambler
23,638
They make reducing tees you could adapt to threaded and screw a gauge in there. It'd be handy for troubleshooting but not sure how many times you'd actually have a use for them.
