The first leak is just above the pump. This is a PVC joint. I don't know anything about repairing PVC.
The second leak is at the pressure gauge on the cartridge filter. There's a crack because someone maybe screwed the gauge in too tight. and cracked the filter housing. Is there a way to repair the crack... maybe epoxy?
Also - I think it's weird it goes from a 2 inch pipe down to 1.5 and back to 2 at the filter. Is there a reason for that? Am I right it should be 2 inch pipe all the way?
