Hi, I've read (more like devoured
) the articles on TFP related to Chlorine, Calcium, SLAM, metals, etc. I just got my 15,620 gallon plaster pool resurfaced here in Miami, FL. I've read the warnings in some articles here regarding using Tri-Chlor Chlorine Tablets and also the warnings on Calcium Hypochlorite and YES, I read the warning to NEVER mix because of dangerous possible reactions/explosion. The owner of the company that resurfaced my plaster pool warned me against using any Calcium products for at least 6 months. Unfortunately, before I got my pool redone, I had purchased a 50 lb BUCKET of Zappit Swimming Pool Chlorine 73% Hypochlorite
that cost me well over $100. I had intended to use it instead of Chlorox Xtra Blue Shock which I've used before my pool was resurfaced. Right now, I am doing SLAM/shock with Liquid Chlorine.
So, QUESTION 1: After 6 months, can I or should I use the 73% Hypochlorite just for SLAM purposes when I need to shock the pool and then when I use up the 50 lbs move to liquid chlorine for SLAM purposes (which I believe is the TFP preferred SLAM method)?? Or given long term effects, should I just try to resell it somewhere (It's UNOPENED/UNUSED) and if so where could I resell it, eBay?? Please enlighten me here.
In the meantime, I am currently using liquid chlorine (10% strength from Walmart) for keeping chlorine levels stable but the same gentleman that I mentioned above who advised against calcium products for six months, advised that I used chlorine tablets in a floating device to keep chlorine levels stable. I have 40-50 unused Chlorox XTra Blue Chlorine/Trichlor tablets that I previously used before in my in-line Chlorinator and before I read some of the Trichlor warnings and warnings against Chlorox products here.
QUESTION 2: Should I consider using up this supply of 40-50 Chlorox Xtra Blue Chlorine/Trichlor tablets and then either switch to another chlorine tablet brand/type or go liquid chlorine from here out? Or given its potential long term effects with CYA and/or metals, should I just bite the bullet and use another chlorine type tablet or liquid chlorine for chlorine maintenance? Please advise.
Obviously, from a cost perspective, the ideal would be to use up my initial investement of Chlorox Xtra Blue Chlorine/Trichlor tablets this summer and then in mid-fall start using up the 73% Calcium Hypochlorite for SLAM/shock until I finish the 50 gallon bucket. I can then transition to liquid chlorine. BUT I don't want to do follow this path at the expense of future problems especially with pool being freshly resurfaced. Looking forward to your comments.
