Thread: Scaling in the heater
    Sep 2009
    Madison, AL (north AL)
    77
    I bought my new house/pool last Aug, and when I closed down the pool in the fall, I discovered major scaling on the inside of the salt cell. I've gotten things under control with the water balance and cleaning up the cell, but now that's got me wondering about scaling inside the heater. I see no evidence of scaling anywhere else in the pool or pool equipment, but I've read on several occasions that the copper pipes inside of heaters are prone to calcium deposits. Is there any way to check this out myself, or do I have to call a professional?
    ph
    25k gal IG freeform pool, gunite/plaster, built in 2006; Aqua Logic AQL-PS-8 control w/ T-CELL-15 SWG; Sta-Rite S8M150 cartridge filter; Sta-Rite SR400NA gas heater; Polaris 280
    Re: Scaling in the heater
    If you aren't having a problem, don't worry about it. In most cases the SWG is the first place to see scaling, so problems inside the heater are unlikely. And even if there is a little scaling in the heater, it won't hurt anything and would be fairly difficult to remove. All in all, it is best not to mess with it.
    Sep 2009
    77
    I like that answer. Thanks.
