Thread: skimmer install on intex ultra frame
    jsf0656's Avatar
    Apr 2010
    south georgia
    313
    hello everyone, i'm installing a thru the wall skimmer on my intex ultra frame pool 16x48 and need some clarification on a couple of things. first, what do i do with the outlet connection since i will have the skimmer hose going to the inlet on the pump and second if i need to apply silicone to the skimmer to help with any leaks that might occur, where would i need to put the silicone, on the inside or outside of the pool wall and between the gasket or skimmer body itself. i'm new to this pool stuff so i could use any advice i can get. thanks for your help!
    18x52'' intex AGP, 6981 gal, 2650 intex sand filter,
    thru wall skimmer, SWG, 52'' 20G overlap liner, intex pool light
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    Re: skimmer install on intex ultra frame
    Welcome aboard!
    I am planning on doing the same thing as soon as I setup my pool (still too cold here).
    The way I look at the gasket/silicon, the gasket sandwiches the fabric of the pool, so that is where I would put the silicon on the inside between the gasket and fabric.
    For some additional info:
    wall-mount-skimmer-on-intex-pool-t16418.html
    soft-sided-skimmer-options-t14766.html
    Mike
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    jsf0656's Avatar
    Apr 2010
    south georgia
    313
    thanks for the reply. but what about the outlet, do i just leave it plugged?
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    Sorry, missed that part, I am planning on hooking up the old outlet along with the skimmer I will install a valve on the outlet. That way I will have two outlets. I am also installing an additional inlet. Most likely this is overboard but it is fun!!
    For those that have installed a standard skimmer did you reinforce the fabric with anything?
    Aquabot Pool Rover
