Results 1 to 7 of 7
Thread: Clear Green Water
    thtmnbhndthecrtn's Avatar
    Apr 2008
    Southern New Mexico
    12
    Clear Green Water
    I, on the other hand, need an idea about my clear GREEN water. It happens after filling and usually goes away in 24 hours, but this time, for some reason, is ongoing several days with no end in site. Any idea about this? ..it almost looks ok, except light, clear green.
    New Mexico, 18000k concrete in ground, 65 degrees, FC 3-5, TA 90, pH 7.3, CYA 30, Borate 40--everything chemically looks good.....
    18000 gal. outdoor, in ground plaster pool; all day sun; 18" sand filter; 3/4 horse pump.
    Re: Clear Green Water
    Try adding a startup does of a metal sequestrant.
    Apr 2008
    Southern New Mexico
    12
    Thanks, will try and report......copper?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    It could be copper or iron; if you have a bluish pool finish, yellow-orange from iron can look green.
    Butterfly's Avatar
    South Carolina
    10,045
    You could have your fill water tested for metals.
    You're done SLAMing when:
    Apr 2008
    Southern New Mexico
    12
    Went to the pool guy and got a quart of Bioguard Remedy metal magnet, 18 bucks. It is diphosphonic acid-based. Put it in, started circulating, and the water was blue and clear as could be in two hours. Just wish there was a cheaper substitute, alas, pool guy wins again.
    Dec 2009
    Central Massachusetts
    2,690
    I've had great luck with HTH Metal Control from Walmart. It's around $10 per quart, its phosphonic acid based, and half the price.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
