Results 1 to 20 of 20
Thread: Pictures of my pool... **FIXED**
    Apr 2010
    Plano, TX
    44
    Brooke
    Plano, TX
    25,000 Gallons, Plaster, DE Filter, No SWG
    Mar 2010
    Spring, TX
    1,082
    Re: Pictures of my pool...
    Not sure if it is because I am at work, but the pictures are not showing up. Just red X in the box. You may want to try to upload them through the site.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    The images are at www.kodakgallery.com, which blocks any attempt to use the images on another site. Try photobucket.com which works perfectly with TFP.
    Apr 2010
    Plano, TX
    44
    Re: Pictures of my pool... **FIXED**
    Okay I think I fixed the pictures. Sorry about that.
    Plano, TX
    The pictures are indeed fixed.
    That is a beautiful pool!
    beautiful!
    14'x28' vinyl liner inground 3.5-6' deep wedge hopper 15000 gal (used to say 13000- I calculated wrong), 1 hp pump with sand filter, 2 returns, 1 fountain, traditional chlorinated, pool house.
    Mar 2009
    eastern washington state
    275
    very nice, nice large pool.
    live in eastern washington state
    18x36, Vinyl inground 24k
    Hayward 1 hp filter pump
    1 skimmer/2 returns
    24" sand filter, polaris 280 with booster pump.
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    NICE!
    14x33 fiberglass freeform
    Variable speed Pentair intelliflo superpump
    420 Clean and Clear Plus cartridge filter.
    pool-school/pool_calculator , http://www.tftestkits.net/
    Mar 2010
    Spring, TX
    1,082
    Very nice
    Butterfly's Avatar
    South Carolina
    10,045
    Beautiful oasis
    You're done SLAMing when:
    ivyleager's Avatar
    Sep 2007
    Raleigh-Durham,NC
    489
    Isn't everything bigger in Texas??
    Lovely pool. I like the brick work and the deck.
    CaryB
    36 x 18 IG vinyl, 25K, 1 HP pump, sand filter
    1 skimmer, 2 returns, no main drain
    Old school: PoolSolutions test kit
    Apr 2010
    Plano, TX
    44
    Thanks for all the nice comments.
    Plano, TX
    scubasteve's Avatar
    May 2009
    Houston, TX
    52
    Love the coping! Is that the Oklahoma Flagstone stuff?
    16,000 Gallon Inground Pool
    Hayward DE Filter
    Polaris 280 Pool Cleaner
    Apr 2010
    Buckeye, AZ 85326
    619
    Awesome pool. When was the pool built?
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    Lana537's Avatar
    May 2009
    The Triangle, NC
    242
    Hello~~
    Indeed a beautiful pool with sparkling water! Mmmm.....Especially nice, in my opinion, is having a classic diving board. I lovingly associate great pools with diving boards into deep ends, sleek lines, and that posh "50's, 60's" aquamarine color to the pool. Simple elegance of a timeless classic.
    Have a wonderful summer!
    Lana
    23,600 gallon, refurbished 1960's inground concrete, Jandy sand filter w Jandy 2 hp variable speed pump, Pool Pilot Digital SWCG+Chemtrol 2100+CO2 tank; PebbleTec White Pearl with 10% Cobalt Blue Dark Beadcrete by Olympic Pool Plastering, Georgia. Taylor K-2006 Test Kit; Aqua Check Salt test; LaMotte borates test, and Jack's Magic Sequest test kit; SparklyPoolitis level: extremely high.
    Aug 2009
    North Central Texas
    1,358
    Quote Originally Posted by ivyleager
    Almost.
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Aug 2009
    North Central Texas
    1,358
    brosaslll, Howdy Neighbor
    Beautiful; everything.
    Did you post some before pictures? If so can you point us to them?
    BobinBaltimore's Avatar
    Dec 2009
    Northeast of Baltimore, MD
    116
    Beautiful pool, brosaslll. Crisp, elegant and not overdone!
    25' x 37' freeform, 22,000 gallon saltwater, 3'6" to 6'6" deep, including baja shelf and benches, 120 ft EP Henry retaining wall
    Pentair equipment (CC420 cartridge filter, VS-3050 variable speed pump, IC 60 salt cell, EasyTouch), 200 sq ft pool house
    View our Pool Build - View our Pool House Build
    Very nice! Love the free form shape.
    Clearwater, Florida
    12,000 gallon kidney shaped gunite pool
    Pentair Whisperflo 3/4HP Pump
    Pentair CCP420 420sq/ft Cartridge Filter
    Pentair Intellibrite 5G 120V Pool Light
  20. Back To Top    #20
    May 2008
    florida
    112
    Nice pool!
