Brand new Hayward Super Pump just humms
Nov 30, 2007
18
Benton, Ky,
I just bought a Hayward Super Pump 1.5 Hp 2 speed pump...
Here's the specs...
According to the diagram...
There are 3 terminals...labeled..."1" "2" "3or4"
The factory hi/lo switch is wired...
black to "3or4"
yellow to "2"
white goes inside motor somewhere
I hooked one leg of my 220v to terminal "1"
I hooked second leg of my 220v to terminal "3or4"
I hooked green to the ground screw on the case
The motor just humms until the motor's internal overload kicks out..
I've tried starting the motor with the hi/lo switch both ways with same results...
I tried bypassing the switch by moving the line "3or4" connection to terminal "2" so that the wiring is..
second leg of my 220v to terminal "2" same results...just humms
I checked the voltage on the legs at the source...seperately and together..
I checked the amps on each leg as the motor is trying to start and get around 3.5 amps on each leg before the motor's internal overload kicks out...
I took the motor/impeller assembly out of the housing to make sure the impeller wasn't binding on anything....
I tried starting the motor out of the housing and the impeller moves about 1 inch before the motor's internal overload kicks out..
Can someone tell me what I'm doing wrong...??
Your wiring is correct with 110 vac to terminal 1 and 110 vac to terminal 3 or 4. Did the box look like it might have been dropped in shipping? With the rotor locking up so soon I wonder if the shaft is bent or a bearing damaged. Does the impellor spin by hand freely? if so ohm the moter leads perhaps its a bad winding.
I use the same pump on my pool and have always had good service from hayward. I hope this helps you out.
