Thread: Brand new Hayward Super Pump just humms
    Nov 2007
    Benton, Ky,
    18
    I just bought a Hayward Super Pump 1.5 Hp 2 speed pump...
    Here's the specs...
    According to the diagram...
    There are 3 terminals...labeled..."1" "2" "3or4"
    The factory hi/lo switch is wired...
    black to "3or4"
    yellow to "2"
    white goes inside motor somewhere
    I hooked one leg of my 220v to terminal "1"
    I hooked second leg of my 220v to terminal "3or4"
    I hooked green to the ground screw on the case
    The motor just humms until the motor's internal overload kicks out..
    I've tried starting the motor with the hi/lo switch both ways with same results...
    I tried bypassing the switch by moving the line "3or4" connection to terminal "2" so that the wiring is..
    second leg of my 220v to terminal "2" same results...just humms
    I checked the voltage on the legs at the source...seperately and together..
    I checked the amps on each leg as the motor is trying to start and get around 3.5 amps on each leg before the motor's internal overload kicks out...
    I took the motor/impeller assembly out of the housing to make sure the impeller wasn't binding on anything....
    I tried starting the motor out of the housing and the impeller moves about 1 inch before the motor's internal overload kicks out..
    Can someone tell me what I'm doing wrong...??
    22K gal. IG rectangular, 1 skimmer 40ft from eq. pad (2" line), 1 main drain 8ft deep-10ft from eq. pad (1.5" line), 2 eyeballs diagonal from each other-10ft & 50ft from eq. pad (1.5" line), Hayward Super Pump 1.5hp, 20" sand filter, 16psi normal operating,
    Re: Brand new Hayward Super Pump just humms
    Your wiring is correct with 110 vac to terminal 1 and 110 vac to terminal 3 or 4. Did the box look like it might have been dropped in shipping? With the rotor locking up so soon I wonder if the shaft is bent or a bearing damaged. Does the impellor spin by hand freely? if so ohm the moter leads perhaps its a bad winding.
    I use the same pump on my pool and have always had good service from hayward. I hope this helps you out.
    coloeb,
    20k gal. IG fiberglass/plaster rectangle 32'x16'
    Hayward Superpump 3/4 H.P. primary Hayward model 5060 Booster Pump
    Hayward Pro Series High Rate Sand Filter
    Pentair Model 320 automatic Chlorine/bromine in-line feeder
    Jul 2009
    London and France
    574
    Doesn't the motor plate state 230V? Is that your supply voltage or 220V or 110V
    You bought this but is it new? If it's new take it back it has faulty windings/capacitor.
