Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: Skimmer Socks vs. Knee Highs
    Guest
    I have been using skimmer socks for a few years now and they work great. I usually have to clean them out weekly. I decided to try knee highs to see what the difference is. I put a Knee High on my skimmer basket over 2 weeks ago and it has not caught ANYTHING in it! I put a sock on the basket this morning and there is already stuff collected in it this evening. My conclusion is that Knee Highs, while cheaper, don't work anywhere near as well as skimmer socks do!
    Maybe this needs to go in the 'reviews' section??
    Thanks for testing this out!!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Guest
    I thought of that but we are really talking about a piece of pool 'equipment' and a common substitute for it. If you think it should be moved please feel free!
    i don't know what your wife would think of you calling her clothing accessories equipment haha. But mine has a tool box full of makeup hahaha.
    Arizona
    925
    I'm really surprised by your results. I haven't tried the knee hi's but was thinking of doing so. Guess I'll stick with the skimmer socks. Thanks!
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    gonefishin's Avatar
    Joliet, Il.
    413
    interesting...thanks for writing your thoughts!
    A while ago I bought two packages of skimmer socks. I just keep washing them and most are holding up good so far
    Maybe I'll just add another package. Hmmmmm
    dan
    33' Aqua-Leader AGP
    Hayward cartridge filter and IntelliFlo VS pump.
    Solar Heat coming ; used to own Aqua-Cal HeatWave 100k (HeatPump)
    Aqua-Rite t-15 SWG
    I have been using Knee Highs for a while now, it really REALLY depends on the quality. The good ones work better IMO than a skimmer sock, but the cheap ones do not.
    Hurricane Rita did not kill me, but she killed my pool!
    Intex 36'X18'x52" "elliptical pool"/ Hayward 220 filter/1HP pump 14,364 gal, or so
    Mar 2007
    Coastalish 'down easter'
    4,160
    Waterbear, et al -
    I've never used a skimmer sock, but have recommended them to some customers with filtration problems. I have recommended knee highs and have installed the first one for folks who have a lot of pine needles dropping into the pool (I carry a supply of knee-highs to add the cya to our new SWCG pools) When I install a stocking in the skimmer basket, it is only to keep the ~larger debris from clogging the impeller and for this purpose, they do well (as long as they don't develop a hole )
    Luv& Luk
    -Ted
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Waste, I agree that knee highs will catch the larger debris floating in the pool, but it's really amazing how much **** a skimmer sock will catch, and I figure, the more I catch in a skimmer sock, the less I'm going to have to hose out of my filter later.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Guest
    Quote Originally Posted by MikeInTN
    Exactly my point!
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    I agree that skimmer socks work great, I've used them since day one and was amazed what they trapped. I can also see though why people look for something else that might do as well since the price of skimmer socks at my local pool store are a rip-off, $10.99 for a pack of 5.
    20x40 IG Vinyl, 1.5 HP Whisperflo, Sta-Rite System 3 (300) Sq. ft Cart
    Intellichlor IC40 SWCG, 125,000 BTU Pentair heatpump, Polaris 280
    7' IG FG Spa, 2 HP Whisperflo, Pentair Dynamic III Cart (100) Sq. ft
    DaveNJ's Avatar
    Toms River, NJ
    520
    When the pollen was bad the skimmer socks had to be rinsed out twice a day. I could pull the basket out and the water would slowly drain out of the basket. They can block the flow allot if they get dirty. Just something to stay on top of during different times of the year.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    Staten Island NY
    116
    I just tried the skimmer sock last week and could not believe how much **** got caught in it, but one thing I noticed is that the gauge on my filter was running at 10 PSI greater than without the sock, even after cleaning the sock. Much like the last post by DaveNj I noticed the water to drain slowly out of the basket when lifted. This occured even after cleaning the sock. This now gives me great concern that I may be putting extra strain on the pump.
    Anyone else having this issue? Perhaps skimmer socks are not a good idea? Should I worry about the pump?
    -400 sq ft ingroung Fiji (straight back kidney) ~ 13,500 gallons - Vinyl Liner - 3 to 6 Feet
    -Hayward 1.5 HP Super Pump
    -Hayward Perflex DE Filter EC65A
    -Hayward H 250 Heater
    Adding a clean skimmer sock shouldn't affect the filter pressure significantly. A dirty skimmer sock is a whole different issue.
    If you are seeing a 10 PSI increase from adding a clean skimmer sock then something is wrong and you should remove the sock.
    Mar 2007
    Knippa, Texas
    289
    Interesting. I have never tried the purpose-made skimmer socks, just used the knee-highs. B/c my pool is indoors, I don't get HUGE amounts of junk in the skimmer basket, but the stocking does catch smallish bugs like pillbugs and some bits of plant matter. I usually rinse the stocking once a week.
    The stockings don't last very long, tho. About 2-3 weeks and they're shot. First the chlorine bleaches them out to an orangey color, then the fabric breaks down. . .
    ~Jules~
    My pool: INDOOR 13x27 rectangular fiberglass, built ~2001, BBB, TA-60 sand filter, Hayward two speed pump (1 hp/0.33 hp), 3/4 hp booster pump for solar heater
    Taylor K-2006 test
    Interesting
    What kind of stuff are you getting out? What size? I am curious. I am well pleased using knee-highs. I think it matters what kind of stuff is around your pool. Grass is bad, leaves are bed, bugs are bad. My knee high catch little black ants. You would have to catch really fine stuff that be smaller than that. I hardly ever have any thing in the pump basket.
    I think the size of knee-hight is important as well. If you use petite vs women's / plus size, that would be big difference, as more stretching is involved. Also, the skimmer basket size has a play in it. Obviously the bigger the basket, the more stretching. If you use small knee-hights on big basket, you definitely would see performance issues. I bbelievethat the skimmer socks are designed to not have to sstretchas much. I would be curious to see diameters of baskets posted with size of knee-highs of those who aren't seeing good results with knee-hights.
    The consensus generally is that uusingsomething is better than uusingnothing.
    If your pressure goes down significantly, something is definitely wrong, whatever you are using.
    36,000 buster crabbe inground vinyl aquagenie
    1 hp hayward sand filter
    Staten Island NY
    116
    I'm using the Bughouse Skimmer Basket Bag. It fit on my skimmer basket fairly easy.
    I have been pulling out grass, leaves and bugs in small quantities in addition to black filth. I have no idea what the black filth is (probably just plain old dirt) but it does not appear to be to thick and comes off very easily with the garden hose.
    I really think the sock might have such a tight weave that it is affecting my PSIs. Perhaps it is the make. As noted before, when I pull the basket out with the sock on, I notice the water to drain out very slowly.
    My next test will be to use on of my wifes knee-highs. I'll punch back in after the knee-high test.
    Any other suggestions are welcome!
    KurtV's Avatar
    Mar 2007
    SE Louisiana
    270
    Re: Skimmer Socks vs. Knee Highs
    Quote Originally Posted by waterbear
    The knee-highs aren't all created equal. Some have a finer and some a coarser weave. The finer ones will pick up more. I tried the skimmer socks starting a couple of weeks ago and don't find them to be catching any more or less than the knee highs I was using were. They are, however, quite a bit more durable than the knee-highs and fit the baskets better/easier. Cost-wise, it's probably six of one, half-dozen of the other as the knee highs are much cheaper but only last a few days on average. I'll probably go with the socks the next time I need to buy.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Re: Interesting
    Quote Originally Posted by mrspock
    My skimmer socks catch all the big stuff of course - leaves, bugs, etc. , but it also catches pollen, small plant matter, and i'm guessing just plain old dirt/dust. the pollen/dirt/dust collects where the water flows through the basket, so I get a greenish/blackish/brownish checkerboard pattern on the sock which I hose off. I'll try to take a picture either tonight or tomorrow night to show you what it catches.
    Intex 8110 SWCG
    "Fear the Schnauz!"
  20. Back To Top    #20
    Baton Rouge, LA
    237
    I wasted $6 at my local pool store on some sox that are too small for my skimmer.
    If you bother to spend the $, make sure you get some large enough for your skimmer.
    I plan to try again soon.
    18,000 gallon gunite free form, with spa, 4x160, EasyTouch, SWCG, Pentair cartr filter, Colorlogic lights.
