Results 1 to 9 of 9
Thread: water scum lines and mr. clean eraser
    Mar 2007
    Richmond, Va
    182
    Did I read correctly on the other forum that a majic eraser by Mr. Clean would be appropriate to use on the scum line that forms around my pool and on my steps by the end of the season?
    18 ft.52" Round Atrium AG -7600 gallons, Sand Filter, Vinyl liner, Royal Entrance Steps, 80 lbs.solarsalt
    East Tennessee
    278
    I would use caution when using the eraser. I have noted a gritty resdue from them when I have used on dark surfaces. I wouldn't use it in the pool but I see not too much of a problem on the steps if you remove them and rinse very well after cleaning.
    Steve
    Echo Canyon II by Artesian Pools, 13.5 KGal AG Round, 22" Artesian Sand Filter 2 hp Artesian pump
    Med Lab Tech for 12 years in E.TN
    Chem testing by Trouble Free Test Kits
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    UPDATE
    PF had a thread on this and someone mentioned that there was a potential problem with the ME and contact with chlorine? I'll see if I can hunt down the info but it was a fairly strong warning NOT to use them in pools - update forthcoming after research.
    UPDATE - FOUND THE THREAD!
    Thanks to Waterbear, who found the MSDS on the Proctor Gamble site - the manufacturer warns DO NOT USE THE MAGIC ERASER WITH CHLORINE. A chemical reaction that can result in damage or injury.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Mar 2007
    Richmond, Va
    182
    Okay, well I guess I'll find other usages for my MR. Clean eraser then!
    So, how do you keep the scum line from forming, or clean it when it does form at the top of an above ground pool? We started getting this at the end of the season last year and just rubbed it off with a wash cloth...hard going...
    Iowa
    38
    I use the Magic Eraser every year to clean the steps, buddy seats, the plastic coping, and the water line of my IG vinyl pool and have not had any trouble at all. I find that it works very well and easy to use. Just used it last weekend when I opened the pool!
    In my opinion, the fear about mixing with chlorine is not a concern since the amount of chlorine is relatively low. I would probably not dump chlorine straight from the bottle onto it, but normal cleaning in the pool has worked very well for me.
    Bruce
    Guest
    Just be aware that the Magic Eraser is actually a very fine abrasive. That is how it cleans. It can cause dullness or scratches in some surfaces. It will also break down in the presenced of chlorine but the amount in a pool is very low so it probably is not much of a problem unless you have just shocked.
    NJ
    292
    I have used it for a couple of years in my pool and it works GREAT. Don't worry about using it in the low chlorine level in a pool. Just don't mix it with bleach - that is what the warning is talking about.
    20x40 IG vinyl, heatpump and solar and 3 siberian huskies, 10kw PV solar electric system. Nikon Photographer D800e dSLR.
    Midwest
    2
    I too use them to clean the scum line and the stairs. No problems at all and no scratching or damage.
    Be careful with them, after a number of years they WILL dull the finish and possibly wear off your print on a printed liner.
    vinyl cleaners and a sponge work well with removing the black suntan lotion scum line and there are vinyl cleaners made specifically for pools that won't mess with your chemistry - either way, the amount of cleaner you use is so minute in comparison to the grand scheme of things that a couple of seagull turds would have a bigger effect on your pool chemistry.
